Ford 2000 top link rocker
   / Ford 2000 top link rocker #1
Mike1208
Franklin, TN
Ford 2000
Anyone have any tips on how (if at all) to get the bushing out of the top link rocker? Mine need to be replaced. I tried hitting it and soaking it some, have Kroil on order. Don't want to bust the rear housing though... 0217170639.jpg
   / Ford 2000 top link rocker #2
Heat it, then let it cool. Spray with pentetrating oil. Try to knock out. Repeat if necessary.
If all else fails, carefully slot the bushing with a cutting torch and knock out.
   / Ford 2000 top link rocker #3
Curious as to what year 2000 that is- mine (a 1963) has a solid steel pin rather than the hollow pin/bushing as yours.
Thanks for the tip.
My 2000 is a 1966 model, 3 cylinder. I believe the previous generation had the same style rocker but I guess that's incorrect.
   / Ford 2000 top link rocker #5
My '65 3000 has a solid pin. I used to have a 66 3000 also and noticed numerous changes over the 65...manufacturing reductions to cut costs. 65 was the first year for the 3 cyl. and like other things (An '88 Ford turck I had as compared to 89 and 90 models) later issues are scrutinized for areas to reduce costs and still maintain functionality.
1993 Ingersoll Rand 185 Air Compressor (A49461)
1993 Ingersoll...
2014 Ag Spray Schaben Sidedresser (A51039)
2014 Ag Spray...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
Grady-White 17ft...
2006 IC PB30500 School Bus (A50323)
2006 IC PB30500...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
