Ford 2000 lift question
   / Ford 2000 lift question #1
marrt
Platinum Member
Northern VA
Power Trac 1845 and 425
Neighbor has a Ford 2000 and the lift only goes up a couple feet. It will maintain this level, but won't go any higher. Any ideas as to the cause? Could he have the draft control in the wrong position?
   / Ford 2000 lift question #2
More than likely he has cam / cam follower pin wear. doesn't take much wear to loose lift resoloution / response.
would help to know if this is the older 4 cyl 63/64 2000 or the newer 65+ 2000.. the lift covers are a bit different on them.
soundguy
Thanks for the reply. He's found a tractor mechanic (friend of a friend) to take a look.
   / Ford 2000 lift question #4
How can I see what type my ford is? It´s a ford 2000 í know that, think it´s called a dexta...not sure, how can I see what model it is?
   / Ford 2000 lift question #5
An import model eh?
soundguy
2013 Dodge Charger Sedan (A48082)
2013 Dodge Charger...
2009 International Ambulance (A49461)
2009 International...
2013 Acura RDX AWD SUV (A48082)
2013 Acura RDX AWD...
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
2013 HINO 388 (A50854)
2015 Top Hat T/A 20 ft. Gooseneck Trailer (A50860)
2015 Top Hat T/A...
