Ford 1910 no charging
   / Ford 1910 no charging #1
Rabduck03
Alton TX
Farmtrac 45, Ford 5610, Farmall Cub, Farmall C, Ferguson TO30
I've gone thru all the wiring on my 1910 and replaced the voltage regulator but the tractor will still not charge. The charge light remains on. I've checked all my connections but still can't seem to find the issue.
Voltage is 12.35 before start and after starting - no change.
Any thoughts?
   / Ford 1910 no charging #2
How old is the battery? Maybe it won't take a charge. If it has a dead cell the light will stay on. Another thing to check is the fan belt, it may be too loose. When the tractor is not running, see if you can spin the alternator pulley with your hand, if you can turn it the belt needs to be tightened or replaced. I always try to eliminate the easy things first.
Belt is good and tight. Battery is about 18 months old. When charged with a charger it works well. I guess I could take it in and get it checked.
   / Ford 1910 no charging #4
If your charger brings it back to full charge in a reasonable length of time the battery is probably OK, unless it runs back down when you are not using the tractor.
The battery charges up fine and holds the charge well.
On the wires going to the alternator
N - with key on it has same volts as battery
Bat+ - always has the same voltage as the battery.
E - ground
F - ??? What should this be when running? With key off motor stopped it has no voltage.
   / Ford 1910 no charging #6
F at alternator should have voltage when key is turned to on to get alternator to start working. Teat procedure is outlined in shop manual FO 44. I can copy it for you but not tonight. I don't know if it will help you or not.
   / Ford 1910 no charging #7
FYI. Scan of FO-44 pages 56-57.
Jc,
   / Ford 1910 no charging #8
Good job JC, now can you do the same thing for pages 54 & 55 which is the test procedure for checking the alternator? Ray
   / Ford 1910 no charging #9
Will do Ray, I have the whole manual scanned plus every other piece of info that I have and of course a jillion of pics.:eek:
JC,
   / Ford 1910 no charging #10
Thanks JC, You have everything on microfilm via the PC. Rabduck03 is having trouble getting his 1910 charging after rewiring it. I am sure these 4 pages will help him. Thanks
VERMEER PD10 PILE DRIVER (A52709)
VERMEER PD10 PILE...
Brock 329,000 Bu. Grain Facility (A57148)
Brock 329,000 Bu...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A56857)
2019 Caterpillar...
2025 GPS Trailers (A56859)
2025 GPS Trailers...
42FT X 36FT METAL GARAGE BUILDING (A58214)
42FT X 36FT METAL...
2006 Godwin GHP45KW-RC45kW Towable Generator (A56857)
2006 Godwin...
