Ford 1710 Timing
   / Ford 1710 Timing #1
sjab55
Dayton, OH
Ford 1710
I have a 1710 that is running rough and I suspect it is a timing problem. I have not been able to identify the number one cylinder. Can anyone help, front or back? Thanks
   / Ford 1710 Timing #2
If you can't find the #1 cylinder, how do you expect to check or improve the timing without a service manual? If you do have a service manual, I'm pretty certain it will tell you all you need to know about fuel injection timing and valve timing. For what it's worth, #1 is closest to the radiator and furthest from the clutch.
   / Ford 1710 Timing
Thanks Rick - I've read the service manual I have cover to cover and it doesn't define No. 1 cylinder which is what led me to post the question. If I were a true idiot I would have moved forward with a guess as to which was No.1
Vacuworx Vacuum Lifter Pad (A50860)
Vacuworx Vacuum...
UNUSED Clear Corrugated Polycarbonate Roof Panels (A50860)
UNUSED Clear...
2022 Club Car...
2013 FREIGHTLINER CASCADIA (A50854)
2013 FREIGHTLINER...
1998 CATERPILLAR TH103 TELESCOPIC FORKLIFT (A51242)
1998 CATERPILLAR...
Cyclone 4826 Sand Blast Cabinet (A50860)
Cyclone 4826 Sand...
