Ford 1710 temperature gauge
   / Ford 1710 temperature gauge #1
davtan
ford 1720
Can anyone assist with advice on how to wire up the standard fit temperature gauge to my Ford 1710 ?
I suspect the thing has been incorrectly wired by a previous owner so I have removed to check it out.
The gauge has two threaded posts which attach to the securing bracket which holds the gauge in position.
There are only two other terminals. One with a threaded nut to which I suspect the wire from the sender unit is attached and the other a, a wire attached by a screw...... maybe Earth ???
Greatly appreciate any help.
Thanks heaps for the site reference.
Lots of information to help sort the problem. This will test me I'm sure.
Really appreciate the fact that you guys are prepared to take the time to help a mere novice.
   / Ford 1710 temperature gauge #4
I was hoping someone with more knowledge would pipe in about your question.
   / Ford 1710 temperature gauge #5
I know this is an old thread, but I was hoping you could tell me what model temperature gauge you installed in your Ford 1710? Has anyone used the universal gauges with the capillary tube?
The gauge in my tractor is the original fitment by Ford. Sorry, but I can't help with info on the aftermarket capillary tube type
1996 Mack RD688S Cab and Chassis (A50860)
1996 Mack RD688S...
2020 PETERBILT 337 BOX TRUCK (A51222)
2020 PETERBILT 337...
2008 New Holland B110 MFWD Loader Backhoe (A51039)
2008 New Holland...
Lincoln Electric Vantage 300 Welder/Generator (A49461)
Lincoln Electric...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A50046)
2018 FREIGHTLINER...
Misc. Office Furniture (A50860)
Misc. Office...
