Oil & Fuel Ford 1710 Recomended Engine Oil ???
   / Ford 1710 Recomended Engine Oil ??? #1
wheeljo
Hello I have a Ford 1710 tractor. What is the proper engine oil for this tractor?
Best Regards
   / Ford 1710 Recomended Engine Oil ??? #2
Best Regards
Below is the factory OEM recommended oil. I have used that along with Shell's Rotella diesel engine oil from TSC with the same weight with no issues apparent to me. I do change oil @ filter at 50 Hrs of my light tractor use.
JC,
There is a few $ saving going to alternate oil than OEM, about $10 per oil change.
   / Ford 1710 Recomended Engine Oil ??? #3
ditto that.. 15w40 'C' rated oil or if in arctic temps.. a 10w30.. though harder to find in 'C' rating... etc.. might have to go to a synthetic in real cold areas..
soundguy
   / Ford 1710 Recomended Engine Oil ??? #4
I also use shell rotella 15w-40. I have done that for 20 years now with no problems.
   / Ford 1710 Recomended Engine Oil ??? #5
It is precisely this time of year, ie; Zero Weather, that causes guys to turn to the 10w-30, or 5w-40 synthetic Rotella T. (WalMart $20 gal)
That 15w-40 would be mighty, mighty stiff at my place this morning. You didn't state your location, but that HIGHLY influences one's recommendation.
Heavy oil turns to super glue at -10.
Industrias America 10F Pull Type 10ft. Box Blade (A50860)
Industrias America...
2015 Jeep Patriot SUV (A48082)
2015 Jeep Patriot...
2004 Volkswagen New Beetle Convertible (A48082)
2004 Volkswagen...
2025 K1119 UNUSED Metal Carport (A50860)
2025 K1119 UNUSED...
2005 Big Tex 10PI 16ft. T/A Utility Trailer (A49461)
2005 Big Tex 10PI...
10x16.5 Tire Assembly (A51039)
10x16.5 Tire...
