Ford 1710 Loader Hydraulic Issues
   / Ford 1710 Loader Hydraulic Issues #1
72F700
Guyton, Georgia
Ford 1710
I need help! I bought this 1710 with a loader a few months ago. The first time I used it the hydraulics quit after a couple hours. The fluid had a lot of water in it. I changed fluid and filter and it worked great. Then I left it in the rain a few times and it got water in the fluid again. I guess this caused the same problem I started with. I also noticed about this time that the 3ph bounces when I have it up. So I changed the fluid again, but not the filter. I just drained the old fluid out of the filter. Now it seems like it only works good until it gets hot. The 3ph seems to bounce until it gets warm. Does anyone have any ideas? Is this a sign that the pump is going out? Any advice is greatly appreciated.
   / Ford 1710 Loader Hydraulic Issues #2
geez I just joined and can't believe nobody chimed in to help you, what did you figure out????
Pretty sure the hydraulic pump is worn out.
John Deere Planter (A50860)
John Deere Planter...
AC CHARGING MACHINE (A50854)
AC CHARGING...
McCullough FG600MK Generator (A50860)
McCullough FG600MK...
2006 FAE Mulcher (A49461)
2006 FAE Mulcher...
2021 Interstate Tiltbed 40TDL 24 Ton T/A Flatbed Trailer (A49461)
2021 Interstate...
Bolens G272 Tractor (A50860)
Bolens G272...
