Ford 1710 Engine Help Needed
   / Ford 1710 Engine Help Needed #1
bucmeister
S.W. Mississippi
JD5300 MFWD
Am trying to help my dad's neighbor figure out where to find some new rocker assembly hold down bolt/studs. As I understand it there are 4 studs holding the rocker arm assembly to the head and 3 of them have broken at the upper end where the threaded portion ends and the smooth part begins. Anyway, he does not have a repair nor parts manual nor a parts source locally for new studs. Figured someone on TBN might could point me in the right direction cause I am drawing blanks.
   / Ford 1710 Engine Help Needed #2
You can get the parts from your local New Holland dealer.
If you want to look for parts online, most dealerships and New Holland North America have online lookup capabilities. You can go to Messicks.com where they not only have the online book, but the pricing of the part that will give you a good idea what the part runs.
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2015 FORD F750 BOX TRUCK (A51219)
2015 FORD F750 BOX...
2019 New Holland C227 Skid Steer (A50657)
2019 New Holland...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A51039)
Mitsubishi FG35...
GENERATOR HOUSE POEWERED BY TWIN 12.7 DETROITS (A50854)
GENERATOR HOUSE...
FRUITLAND VACUUM PUMP (A50854)
FRUITLAND VACUUM...
