Ford 1700 Hydraulic Question
   / Ford 1700 Hydraulic Question
It's smooth until you stop then it starts bouncing. I'm gonna get a gauge and check it but it occurs at all throttle positions
   / Ford 1700 Hydraulic Question #42
it might be that when it arrives at desired height the spool does not divert unused oil smoothly to the diffy. it might be that main relief pressure is set too low. I asked the question if it does the same with load or no load. answering to questions asked will help to formulate an opinion. it also might be the feed back control is not adjusted right and causing the jerky motion. can you video 3 point lifting it with or without weight?
It lifts smoothly with or without a load however when you reach the desired height and stop it begins to bounce up and down a bit. It does not bounce without a load on it only with an implement hooked up. I will try to video it. In regards to relief pressure I would have to hook a gauge to test right?
   / Ford 1700 Hydraulic Question #44
Ok. need to know the pressure. Pressure gauge should be attached to the lift cylinder head on the right side facing forward sitting on the tractor seat. right at you right knee.
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2007 International 4300 Dump Truck (A51692)
2007 International...
2023 John Deere 8RX 370 Track Tractor (A53485)
2023 John Deere...
Pallet of UV Solid Hardwood Flooring (A53424)
Pallet of UV Solid...
2005 Dodge Caravan Van (A54815)
2005 Dodge Caravan...
2015 GMC Acadia SUV (A55853)
2015 GMC Acadia...
