Mar 3, 2013 / Ford 1320 #1 C chevyman51 New member Joined Mar 3, 2013 Messages 2 Location Hamilton, Ohio Tractor Ford 1320 I have a 1320 and I was wondering if I could install hydraulic remotes on this tractor since it did not have them on it when I purchased it? Thanks for any help
Mar 3, 2013 / Ford 1320 #2 J_J Super Star Member Joined Sep 6, 2003 Messages 18,952 Location JACKSONVILLE, FL Tractor Power-Trac 1445, KUBOTA B-9200HST You should have this Hydraulics: Type: open Capacity: 6.9 gal [26.1 L] Pump flow: 6.7 gpm [2 What do you have now for hyd? 3pt system only?. There are ways to do most anything. Do the hyd have internal lines or external lines? Any rubber hose or steel line going to the back? Last edited: Mar 4, 2013
Mar 4, 2013 / Ford 1320 Thread Starter #3 OP C chevyman51 New member Joined Mar 3, 2013 Messages 2 Location Hamilton, Ohio Tractor Ford 1320 It inly has the 3 pt system on it
Mar 4, 2013 / Ford 1320 #4 J_J Super Star Member Joined Sep 6, 2003 Messages 18,952 Location JACKSONVILLE, FL Tractor Power-Trac 1445, KUBOTA B-9200HST Can you see the pump output hose?
