Ford 1310 steering issues
   / Ford 1310 steering issues #1
Murphman
Frewsburg
Ford 1310
Hello,
In need of some advice on the steering gear box on my 1310. The sector shaft has all the teeth broken off and the sleeves in the case are really worn. Anyone know where a guy can find the parts needed? The part number for the shaft is SBA334130040. The only one I can locate is a SBA334130041. It looks like with a bit of machining this one might just work. Just looking for a a little advice or help locating parts.
Thanks Guys, Lance
   / Ford 1310 steering issues #2
New Holland show the part for about $460 and Walt's Tractor an aftermarket for slightly less. The part #sba334130041 is for 1300, 1500 and 1700 box.
If you are looking for used, try West Kentucky Tractor Parts.
   / Ford 1310 steering issues #3
Another option that might be viable is to contact a salvage yard and see if they will sell you an entire box.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51242)
KNOW BEFORE YOU...
2025 K1912 UNUSED Metal Livestock Shed (A50860)
2025 K1912 UNUSED...
Brown 417 7ft Rotary Cutter (A50490)
Brown 417 7ft...
Vacuworx Vacuum Lifter Pad (A50860)
Vacuworx Vacuum...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
GORMAN RUPP 4 TRANSFER PUMP (A50854)
GORMAN RUPP 4...
