For the newbie.
   / For the newbie. #1
Shield Arc
Super Member
Port Orchard, WA.
John Deere, 4200
Any of you guys just starting out with your new welder, here is a quick and easy way to see if you're ready to start building things. Like trailers, trailer hitches, etc, etc. You'll need a few tools along with your new welder. Grinder, band saw, or torch, Harbor Freight Compact Bender, (part # 38470) works really well. Use the 1 1/2-inch die.
Here is an AWS test plate. You can run this with any process, SMAW, (stick), Mig, or Tig, and in any position.
I ran this test on open root pipe, in the 5-G position, using 6011.
Cut your coupons as per the AWS test plate.
Grind down the welds, and use a sanding pad to smooth the coupons. Place the coupons in the Compact Bender. You'll want a face, and root bend.
Look for any flaws in the weld.
If nothing else this is a very good confidence builder! ;)
2018 Chevrolet Tahoe 4x4 SUV (A50324)
2018 Chevrolet...
2015 Ford F-150 4WD (A51039)
2015 Ford F-150...
UNUSED 120 Pairs Safety Work Gloves (A50860)
UNUSED 120 Pairs...
2023 John Deere 6110M Utility Tractor (A50657)
2023 John Deere...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A51039)
Kubota 24in Quick...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
