Floating a Tree Stump with a B3030
   / Floating a Tree Stump with a B3030 #11
Glad that method worked for you however I don't think it could help me. A stump that big would bee a challenge for even a big tractor but it seems to me you are still going to have to cut through several of those lifeline cables known as roots. Maples are of course a hardwood and until you get around the stump and cut off all those cable like roots that stump is going to stay tethered to the earth just like a boat stays tied to a doc.
I can see where that method you used might help me in a different way. I like to undermine some of those big stumps and if I could get a blast of water under there like the errosive effect from a garden hose I believe you could jet the earth clean away from those roots. In my case however my soil is gravel and the water can practically race into the soil. In other words it just would not pool before it would be traveling down and away. The stumps I have dug I am afraid would fail to float any way because of all the weight from the gravel it comes out of the heavy earth soil attached to those roots.
Pretty clever effort and glad you got that old stump out.
   / Floating a Tree Stump with a B3030 #12
Did you WAX the stump after you washed it ??? :D
   / Floating a Tree Stump with a B3030 #14
Wax Man,
They should make this thread a "sticky". It's a great concept.
I think that your advantage is turning the solid ground that helps resist stump removal into mud. So the lesson here is dig around the stump to make a moat and if the stump still won't come out, return later after a good rain. (Since most stumps aren't within a garden hose radius of the house)
John
   / Floating a Tree Stump with a B3030 #15
It is a known fact that trees roots will loosen up during and after a good rain. A good wind will wreak havoc in a rain soaked forrest.
So if you are going to remove a tree or stump, just soak the tree roots about 24 hr before digging or pulling the tree over.
   / Floating a Tree Stump with a B3030 #16
Excellent idea. I have some big oak stumps I'd love to remove. I'll give it a try.
   / Floating a Tree Stump with a B3030 #17
Nice job with the stump. I love the pool area.
That is a very nice looking place you have there. That was a good idea on getting the water in an around the stump to loosen up the soil, let some of it wash off etc to lighten the load. That stump was about as big as your tractor from the looks of it. Glad you were able to get it out. THEN what did you do with it?
Thank you,
What I did with the stump.
I went out back and dug a hole for it. Like you said, it was as big as my tractor so I made sure I dug a hole that big.:D My wife comes out and yells WHAT ARE YOU DOING ??!!
"Nothing ......"
   / Floating a Tree Stump with a B3030 #19
Ever tried a pressure washer?
Bruce
   / Floating a Tree Stump with a B3030 #20
Thank you,
"Nothing ......"
Remember wnere you burried it because at some point when it rots youll have a tractor sized sinkhole. Cool technique and nice place
2019 Komatsu PC490LC-11 Hydraulic Excavator (A49461)
2019 Komatsu...
2013 HINO 388 (A50854)
Killbros 260 Seed Conveyor (A51039)
Killbros 260 Seed...
1968 John Deere 4020 with 7ft Mower (A51039)
1968 John Deere...
71061 (A49346)
71061 (A49346)
1991 International 4900 Box Truck (A51039)
1991 International...
