Fixing paint chips and small rust spots
   / Fixing paint chips and small rust spots #1
powerscol
SW Colorado
CT 235
What is the best way to fix paint chips and small rust spots. I start with a bit of sanding then I use small art brushes and fill in a dab of primer, then when dry, paint over with the color needed. I was thinking of wiping with phosphoric acid first (rust converter) then sand, clean with acetone, and paint. These are all little spots from rock chips, etc.
On longer scratches I have taped along the edge and use spray to cover. usually using Rustolium products to do this from HD or the local hardware place.
Is there a better way?
Thanks
   / Fixing paint chips and small rust spots #2
Better? I doubt it. Sounds like you do fine. I like using RustOleum because it contains rust converters in it. I keep rattle cans and brush cans around in the colors I need for touchups.
   / Fixing paint chips and small rust spots #3
I have found that for really small chips that are rusted, I can use the tip of a drywall screw to scrape all the rust down to bare metal. Also use it to scrape away any loose paint. So I am left with a chip that's down to bare metal and surrounded by all good paint. Then fill it in with the paint/primer of your choice. Artist brush works well, but sometimes the tip of a toothpick can be dipped in the paint and then stuck in the chip to fill it. Have also gotten some touchup paint that's in a pen, which you can use to "flow" into the chip to fill it.
I like your suggestions as I have used them all . One other thing I have tried is the Q-tip to put the rust converter on. I let it do its thing and then check for loose paint. Q tip is lousy for paint as it leaves fibers, however I found a set of foam art brushes at Walt-Mart. Set has small shapes (round, square, triangles) that do work well.
UNUSED 2-Pack Yellow Outdoor Patio Fabric Screen (A50860)
UNUSED 2-Pack...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A51039)
Mitsubishi FG35...
80in HD Tooth Bucket with Side Cutters (A51039)
80in HD Tooth...
Adams Conveyor (A51039)
Adams Conveyor...
Headache Rack (A50860)
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
