First experience with Kubota Warranties in 25 years, first bad experience with Kubota
   / First experience with Kubota Warranties in 25 years, first bad experience with Kubota #111
Slack in the peddle doesn't cause brake wear.
But when his peddle went down and wouldn't return the brakes for whatever reason were apparently stuck on and continuing to drive with the brakes stuck on burned of the lining.
I would think that the thing to do would have been to manually pull the pedal back up after starting a tractor if you have to push the pedal down to start it. I don't recall having to do that on our BX2660, but I don't drive it all that often and the tractor in question may be different.
Aaron Z
Pedal did not stay to the floor after starting, it just didn’t return to the top where you normally have free play. It was just like a spring was missing.
   / First experience with Kubota Warranties in 25 years, first bad experience with Kubota #113
what got me the most was the rep stating it was operator error due to driving while riding the brake. It's not even comfortable to hold the brake down.
I believe you, and if you rode that pedal for a year or two there would likely be some wear on the pedal surface.
If the pedal looks unused it kind of makes your point.
They saved money denying the claim, fact.
What bothers me about this thread is when you know you are telling the truth and they state the cause as something that infers you were not truthful.
That would bother me far more than the financial cost of the repair.
Sorry- not trying to re ignite an argument, but when truth and honor are questioned well...
AMEN sd455dan -- I agree 100%. That would be exactly my thinking if I were in the 628 shoes. It is very clear that 628 DID NOT hold the brake down or ride it and the rep was erroneously accusatory in claiming so -- with no proof of any kind. Another point: 628 said a few posts back "Pedal did not stay to the floor after starting, it just did not return to the top where you normally have free play. It was just like a spring was missing."
That is profound BECAUSE 1) it proves the problem of the sticking brakes was an internal malfunction and had nothing in the world to do with operator error. And 2) I would bet that 628 told the dealer exactly what he just told us -- Blue sentences above ending "...like a spring was missing." If in fact 628 did tell the dealer that, the dealer should have told him with no further discussion THERE IS AN INTERNAL PROBLEM, DON'T USE IT UNTIL WE LOOK AT IT. That is on the dealer totally, no one else. As I understand industry norms Kubota has to back this claim for 2 reasons: First it was an internal failure of some sort during the warrantee period and Secondly the dealer (probably) goofed failing to tell the customer to stop using it until investigation was done. Kubota is responsible for actions of the dealer too in that context.
   / First experience with Kubota Warranties in 25 years, first bad experience with Kubota #114
You are out of line to say that kubota is responsible as well as saying that it was an internal problem with the tractor to begin with! The petal might have just not been returning to the top of it's stroke do to it being tight on the shaft or an issue with the return spring. Anyway you look at it to move the machine at that point the brakes were lightly engaged which caused to heat to hurt internal components while operating the tractor..
   / First experience with Kubota Warranties in 25 years, first bad experience with Kubota #115
This has been my position from the beginning.
   / First experience with Kubota Warranties in 25 years, first bad experience with Kubota #116
That does not change the points I made nor the conclusions. I don't think my reasoning is out of line at all.
   / First experience with Kubota Warranties in 25 years, first bad experience with Kubota #117
I have a B7800 that I bought new in 2005 and by and large am very happy with. I have found though, after losing the dif lock twice and one broken front axle that their quality control has slipped.
The first time the dif lock went out my son in law had done some mowing for me and even though he is a very good equipment operator I thought maybe he was riding the lock pedal, which he denied, and I now believe him.The second time it went out, about 250 hours later no one but me had run it and After the first experience I knew darn good and well that I hadn't caused it to fail. This time as I was putting it back together I was very careful to check every little detail and found that it was binding where the rod goes into the dif case and it was not releasing all the way.I of course did a little bending and reaming and a bunch of greasing. So far so good but I watch it like a hawk.
I think this is caused by the way it was designed. The dif lock pedal is on the left side of the floor and connects to a rod that goes under the tractor to the right side then connects to another rod that goes back to the housing and connects to yet another rod that goes through the dif housing. Neon of these connections are machined or bushed,just a bent rod through a drilled or punched hole, way too much room for error.
On the front axle I was mowing a fairly flat area when the left front axle snapped. After getting the tractor back to the shop and taken apart I saw that the axle stub had only been welded half way around to the part it attaches to. If I had seen this without knowing where it came from I would have guessed it was Chinese.
I've owned 3 older Kubota that were worn out when I got them an could never fault any design flaws but the newer ones seem to have problems.
   / First experience with Kubota Warranties in 25 years, first bad experience with Kubota #118
The bottom line is Kubota is within their rights to refuse to cover it under warranty. At the same time we are not obligated to continue to buy their products. If it was me and Kubota told me that it was my fault I most likely would never buy another Kubota again. Situations like this are when a company has the chance to step up and make it right or look at the bottom dollar. If the pedal wasn't returning to it's normal position on a low hour/ new tractor then either something unusual happened (like corrosion) or it was a manufacturing mistake. If it was something unusual then the dealer should be able to point it out. The brake pads/ rotor are just a casualty of the problem.
Would you accept a car company telling you that it was your fault that your new car just ate up one of it's tires because they built the rear axle wrong? I wouldn't. Far too many brands out there. Kubota and Deere seam to charge a premium, if excellent service is not something you can count on then that's an easy way to loose market share. My Deere riding mower that I bought used (1 year old from a different dealer) had to have the steering wheel replaced. The local dealer didn't say a word, just ordered it and installed it. When I went to pick it up the dealer said that the seat had a small tear from what looks like the vinyl being too thin or someone put a rope across the seat and wore it down. It was there when I bought it so I figured it's up to me to repair it. They ordered a new seat under warranty and told me to wait until the warranty is closer to expiring and they would change it. That's what I expect from a premium brand.
   / First experience with Kubota Warranties in 25 years, first bad experience with Kubota #119
I don't see anything here that is Kubota's fault? But ya, you should all stop buying them so they lose business and their prices come down and I can buy more cheaper, LOL.
   / First experience with Kubota Warranties in 25 years, first bad experience with Kubota #120
After skimming through 6 pages of bottom lines, is the tractor fixed yet? Thats what I was looking for, that post. If not and if the dealer isn't and kobota isn't going to fix the tractor it's time for a plan B...
Ether pay the dealer to fix it or I suggest fix the brakes your self, how hard can brakes be to fix on a BX tractor, just a bunch of bolt turning and torquing, and why do bearings have to be replace for just those few what was it 200 hr. and why $1000.00, what does brake pads cost? All's needed is drain fluid, remove brake housing, it only gets hard if gears have to come apart and thats only inside trans on a manual. Best of luck and Merry Christmas.
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
SIDE WINDER 14' ROTARY MOWER (A58374)
SIDE WINDER 14'...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
2014 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A58214)
2014 HEIL TRAILER...
M998 (A55852)
M998 (A55852)
Troy-Bilt Push Mower (A55973)
Troy-Bilt Push...
