finish mower vs. sickle bar
   / finish mower vs. sickle bar #11
Yep, smart move. You'd be burning belts off and going really slow trying to mow 12" grass down to 6" with a RFM
   / finish mower vs. sickle bar #12
The clippings can ferment, can become impacted, or otherwise cause digestion problems. Big difference in cow and horse digestive systems/ stomachs.
   / finish mower vs. sickle bar #13
Very true - he would be better keeping the horses in one pasture and let the other grow and hay (12 inches is very good for haying). Find someone to cut and bale. That would maintain the pastures better. Rotate through the cut and uncut with the horses.
   / finish mower vs. sickle bar #14
Here's to an open can of worms: think about a flail mower!
Jim
   / finish mower vs. sickle bar #16
I have a 7 1/2' sickle mower and a 5' 6" brush hog. I previously had a 7' finish mower and a 6' brush hog. Based on my experience, and IMHO, I would not buy another finish mower, because the brush hog mows large areas about as well as the finish mower. The brush hog is indispensable for mowing rough stuff. I use the sickle mower to a/ mow around the edge of a pond and b/ to mow the edges of trails, roads, etc., with the sickle bar turned up 90 degrees. The application of mowing with the cutting blade turned 90 degrees up saves a huge amount of time that it would otherwise take to trim the edges of the roads and trails by hand. But if I had to pick one and only one, I would choose the brush hog because of its versatility and the fact that on average I do more mowing of fescue in the open without baling it and of brush, weeds, etc., on the roads and trails.
   / finish mower vs. sickle bar #17
I use a 9' sickle (NH479) to cut hay for baling and also for trimming pastures. I mostly use a Woods 84" rear discharge finish mower to trim to a higher length. The Woods does a better job because the cut grass rots off a lot faster and it distributes the horse poop nicely if set down to that height. My JD1070 runs it in high gear easily. I set the gauge wheels down for the highest cutting height. I only use the two lower links and don;t bother with the top link. Then you are just dealing with a trailer mower.
Sharp blades are mandatory.
   / finish mower vs. sickle bar #18
Ever consider a flail mower?
John Deere 7000 8R Planter (A59814)
John Deere 7000 8R...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 John Deere 35G (A55272)
2019 John Deere...
2015 Ford Escape SE (A57148)
2015 Ford Escape...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
