Finally I now have my 640, now what?
   / Finally I now have my 640, now what? #21
let us know how it turns out.
Well I finally had a good weather day so I set out to take care of the hyd problem. I drained the fluid and pulled the manifold. The pump repair kit had 5 O rings so I thought I was all set. I matched up the two O rings on the tranny housing end but the pump end had a couple of rings that were not O rings, they looked more like gasket material. So, I put the gaskets back in and buttoned it back up. I filled it with fluid and primed the pump. The recommended method of turning the engine over with the starter to prime the pump was not working (maybe I was impatient) so I fired the engine up and the pump immediately gushed forth. I reinstalled the primer plug and the lift worked like a charm. I shut the tractor down and proceeded to tackle other issues like straightening out the wiring. After a bit I decided to sttach the lift boom pole and preposition some of the implements. The lift was kaput. I removed the primer plug and the pump had lost its prime. I can imagine it was my using the old "gaskets". Can I use any O ring that is the correct size - I have a box of O rings from Harbor Freight and I am sure I can match the size. I did notice in the reassembly that one of the bolts in the manifold, tranny housing joint was nearly stripped out, I pulled it tight but did not bear down on the wrench - I am fairly confident the bolt is tight enough but I am not sure.
Is the O ring set up that sensitive to air leaks?
Thanks, Russ
   / Finally I now have my 640, now what? #23
there are flat face orings that are pretty specific to that application. if you can't tighten down correctly. it CAN loose prime.
other prime loss areas are the shaft seal internal to the pump.
Given the sound advice from sounDguy, I decided to trust the work and try priming with more patience. It worked! I had a little bit of chatter and I lost the prime overnight but since then it seems to be doing fine. I broke down and bought a new voltage regulator as the old one was just not behaving. The new regulator is in and it is working fine. I buttoned things up today and put the tractor to work. I hooked up a disc-harrow and worked up my son's garden. It sure felt good tillin' the soil.
I still have lots of work to do but I am hoping I can keep it running this summer. Next winter I hope to have the time and money to make her showroom pretty.
I will start a new thread when I get some pictures and when I encounter new problems.
The other day, our bug guy (pest control) stopped by to do a treatment and he saw my scrape blade in the bed of my truck. He said he had just picked up an 8n and 4 attachments for $800. I told him about this web site and told him it was as essential as an overhaul manual when it comes to getting things fixed.
Thanks for all of your help - I hope I can someday be a part of the solution instead of part of the problem.
Russ
   / Finally I now have my 640, now what? #25
deffinately a good website here!
8 Piece Excavator Heavy Duty Attachment Set (New/Unused) To Fit CAT 301 (A59225)
8 Piece Excavator...
Yanmar YT359 (A53317)
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
