Finally a KUBOTA owner!
   / Finally a KUBOTA owner!
That's perfect! Never would I have thought of mounting it there! Perfect location, I believe. I'll look at my layout when I get home in a bit! Did you use some type of gasket between the Ram base and the tractor housing?
Thanks J Wal!
No gasket. It’s just the base straight on the plastic. I held it in the general location I wanted it and used a marker to trace half of the mounting base. That way I could get on the side of the tractor, line the tracing up with the mount base and drill the holes.
I do feel the metal tabs I used on the back of the top and bottom bolts will go a long way to prevent the mount from pulling the bolts through the plastic.
I also used blue lock tight on the bolts/ nuts to prevent loosening from vibration.
I am really happy with the low profile to the hood yet easy to see and access. Should be fairly safe from being hit by limbs or anything like that.
   / Finally a KUBOTA owner! #52
I loved my l3830, never thought I'd replace it, then we had a little fire last October, I still regret not driving it in the pool.
   / Finally a KUBOTA owner! #53
Another California fire scorched the Kubota 900 RTV...
Rubber/Plastic melted but mechanicals OK...
   / Finally a KUBOTA owner! #54
I picked up my replacement rtv a few days ago, bad engine, probably a head gasket. Just a great reason for a complete overhaul with a turbo!
   / Finally a KUBOTA owner! #55
One person's loss is often another's gain.
As I write... the family is in Bavaria on holiday... don't see many Kubota Tractors over there yet but with each visit I see more.
Picked up a 6’ landscape (root) rake and a middle buster for $400. Was going for the rake only for $350 but talked them into $400 for both. No need as of now for a middle buster but for $50 why not. Lol
2014 Freightliner M2 106 Palfinger PK22002EH 6 Ton Knuckleboom Flatbed Truck (A55973)
2014 Freightliner...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
LOT: (6) Grease Guns (A59076)
LOT: (6) Grease...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
Toro GreensMaster 1600 Walk-Behind Reel Mower (A55787)
Toro GreensMaster...
(2) EVENRUDE OUTBOARD MOTOR (A58374)
(2) EVENRUDE...
