Finally a fix for the warning light on the Lxx60s with a high output alternator
   / Finally a fix for the warning light on the Lxx60s with a high output alternator #1
Fallon
Super Member
Parker, CO
Kubota L4060hstc, formerly L3200hst
When I got the machine over a year ago, the dealer noted the warning light on the dash would light up & stay on unless you immediately started the machine from the off position. If you ever turned the key on & left it there for more than a second or 2, the warning light would kick on & stay on until the key was turned off. Apparently a bug relating to the high amp alternator upgrade. Slightly annoying, but never problematic, so I ignored it.
I finally got my L4060 into the dealer for some warranty hydraulic work. And when they dropped the machine back off, they mentioned there is a fix now & it was applied (updated firmware on the computer I assume). Light doesn't seem to come on anymore.
   / Finally a fix for the warning light on the Lxx60s with a high output alternator #2
I wasn't aware there was a high output alternator option available for the LXX60 series. I wonder if it's available on a ROPS model or just cab tractors? Had I known, I would have ordered it on my L6060 HST ROPS. I've run the battery down a couple of times already powering a 12V to 120V inverter.
Next time I'm out there, I'll ask if it's a dealer installed option and, if so, the price. Thanks for the info Fallon.
I'd assume it's an option for open stations as well. It's required if you get the rear defroster, probably a few other things.
I may have gotten it even if I didn't need it for the defroster. I wired in an auxiliary fuse box in the cab I could probably jumpstart with. Lots of extra lights already. Http://www.tractorbynet.com/forums/showthread.php?t=376458
Bolens G272 Tractor (A50860)
Bolens G272...
Deere 9970 Cotton Picker (A51039)
Deere 9970 Cotton...
2012 Ledwell 130BBL Vacuum Trailer (A50860)
2012 Ledwell...
2022 ELITE 102" X 40' GOOSENECK TRAILER (A50459)
2022 ELITE 102" X...
UNUSED Portable Bathroom and Shower (A50860)
UNUSED Portable...
UNUSED 2-Pack Black Outdoor Patio Fabric Screen (A50860)
UNUSED 2-Pack...
