Filter Cart
   / Filter Cart #1
SpringHollow
Elite Member
South of Rochester, NY
Power Trac 1850, NH 2120
On Saturday, I finished building my filter cart and modifying the cover on the PT 1850 for the quick connects to the hydraulic tank as well as the tank magnets and a thermometer. I am happy with how it turned out but I might do a small tweak on it yet - add a valve to cut back a little on the flow and pressure. The pump I am currently using will pump 4.5 GPM (measured) through the filters when the oil is at 60 degrees F and about 2 GPM (from chart) at 0 degrees F. I also want to measure to see if there is room on the PT to see if I have the option to use a 12V pump and run it while using the PT. Hopefully, I can post pictures, etc. this weekend.
The main reason I am writing now is that there is a filter cart on Ebay:
eBay: HYDRAULIC FILTER CART PORTABLE TRANSFER PUMP PARKER (item 110135714972 end time Jun-12-07 18:24:38 PDT)
It is 26 years old and it does not say what micron ratings the filters are. Worst case, you could add an inline 1 micron filter. I have not checked the specs for this particular unit but they usually run $1400 - $2000 new. By the time you ship this one, you will be at $500 or more. You can definitely build one cheaper than that, much cheaper if you can buy a used pump or scrounge some parts. It is not easy to find a pump rated for 40 - 100 psi, viscous oils (especially cold oil), 170 degrees F, and self priming. I ended up buying a used industrial process pump for $55 - my guess is that it costs way over a grand new. The used pump needed a starting capacitor but it works fine after getting that. For the filters I am using, I need at least 20 psi. (The cheap $40 pumps that I have seen are rated for 30 minute duty cycles and may not be able to pump very hot oil or cold oil - I might try one at some point for yucks just so people know if they work for this application). The filter cart on Ebay might be a good deal if you are going to buy one instead of building one, especially if you can pick the Ebay unit up instead of having it shipped.
Ken
AIR POWERED TONGS (A50854)
AIR POWERED TONGS...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
20 ft. Shipping Container (A50860)
20 ft. Shipping...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
196046 (A50459)
196046 (A50459)
2025 K1119 UNUSED Metal Carport (A50860)
2025 K1119 UNUSED...
