Fiixing squeaky sub-floors
   / Fiixing squeaky sub-floors #1
wngsprd
Super Member
Beaverdam, Virginia
Kubota L3130 DT
We are getting new carpet in 3 rooms, scheduled for next Thursday.
I have a few floor squeaks I want to fix...either before the installers come, or after they pull up the old carpet, but before the new goes down. But I don't want to hold up their progress.
We have plywood sub-floor over joists in these rooms. I can access them through the crawl space, by removing insulation, but thought with the old carpet coming up, screwing from the top would be best.
3 Questions:
1. "Squeek-no-more" kits - have you had success with these screws with the heads that pop off under the plywood sub-floor? They state that can be drilled through existing carpet. A bit pricey compared to regular screws.
2. Are 1 5/8" self tapping screws the best to use otherwise?
3. Any other tips?
Thanks, Billy
   / Fiixing squeaky sub-floors #2
I'd use a 2-1/2 inch subfloor deck screw -- that's what they are made for. Normally have a square drive or star drive head, and will be yellow-zinc color. They are made to be used in a self feeding screw gun mounted on a stick, so you can walk around an entire new home and screw all the floor joints before flooring goes down. But in your case, just get them loose and put down with an impact gun or drill. I have seen them sold at Lowes and HD as wood project screws, in the section with loose screws in bins. Probably come in a pack too.
No reason you couldn't use a regular #9 or #10 exterior deck screw either. Basically the same thing but with special coating.
Do not use a drywall screw, as they are brittle and won't take the required fastening torque for this use.
   / Fiixing squeaky sub-floors #3
Squeak no more works.. BUT, after sinking a bunch of them I found some squeaks in the hallway were not the floor after all. They were the bottom plate on the walls. I was able to fix by going underneath and shooting long screws at an angle thru the floor joist (drilled thru here) up into the lower plate of the wall. Problem solved.
   / Fiixing squeaky sub-floors #4
Grandma's place had two spots...
All I did was get a tube of adhesive caulk and drilled a small hole just large enough for the tip so I could pump in caulking.
That was over 20 years ago and no squeaks!
   / Fiixing squeaky sub-floors #5
I agree with s219 and would use deck screws with either a star or square drive. Both work about he same, but I tend to buy the star drive most of the time. 2 or 2 1/2 inch screws at least every 12 inches and probably every six inches with the head screwed into the wood so it's lower then the height of the wood. I use a Makita driver and highly recommend drivers over drills. No twisting or wrist fatigue with a driver and they are a lot more powerful.
Eddie
   / Fiixing squeaky sub-floors #6
I highly doubt you will have time to fix the squeaks during the carpet install. They work fast and nothing really slows them down untill the new carpet is down then they go to work edging,gluing, tacking, cutting.
If I were you - if you are not able to remove the carpet, I would cut a 4 ft wide section out of the area that squeaks and go to work screwing down the floors. Can you access the floor from underneath too? I would squeeze subflooring glue in the corners before screwing down the floor. This way, if there is still one spot squeeking no matter how many screws you put in, the glue will harden over the next few days before the floor install. Same goes for the flooring that meets each other on top -- use putty knife to force the glue in the edges. You dont need to do every single seam- but only where the squeaking is since you need the expansion/contraction movements. I have used this method with success.
Thanks for the help. I already have 2 and 2.5 inch deck screws (star drive) and will try the glue/caulk approach. I may go the Squeek-no-more route to get a head start, since radioman cautions about how much time I may (not) have when the carpet guys are here.
   / Fiixing squeaky sub-floors #8
Carpet getting replaced, just slice / cut the old carpet where it's needed, Now!!! :)
   / Fiixing squeaky sub-floors #9
Have you tried to isolate the exact locations of the squeaks? (i.e., one person to make the squeak and another under the system)
Many times the culprit is a nail that did not get driven home fully and just a bit of flex in the sub-floor will cause it to squeak...
   / Fiixing squeaky sub-floors #10
+1
We tried squeek no more. Worked about 50% of the time. Tear up the old carpet and use the deck screws. We ended up doing that anyway and fixed every one of those derned squeaking nails. If the nail is the squeak it will never be fully stopped because the "give" in the floor will eventually work it loose again. Eddie is 100% on target.
2016 KENWORTH T660 SLEEPER (A50854)
2016 KENWORTH T660...
2014 INTERNATIONAL PRO STAR (A50854)
2014 INTERNATIONAL...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A51039)
2022 New Holland...
2016 Chevrolet Impala Limited Sedan (A48082)
2016 Chevrolet...
