FEL wear blade
   / FEL wear blade #11
Shillingcl, I saw the below posting you did on this thread in Oct 12. Where did you obtain the urethane edge from, and did you have to fabricate it at all. Was the FEL edge guard from BX panded? Thanks.
Your post : I bought a wear bar for my BX which I leave on all the time, but also drilled holes in that so I can put a urethane edge on in the winter so I don't tear up the concrete. The only regret is that I didn't totally understand how the urethane edge would be attached, so I ordered it with measurement for the inside of the bucket instead of outside, but not a big issue. Attached are some pics of the wear blade with edge attached and also the lighting I wired in at the same time.
   / FEL wear blade #12
Has anyone tried or own the Ratchet Rake Snow Edge? I would think that this would perform fairly well on a finished blacktop driveway.
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
40' High Cube Multi-Door Container (A57149)
40' High Cube...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
PALLETS OF HEAVYEQUIPMENT (A58216)
PALLETS OF...
Rooster Weathervane (A55853)
Rooster...
