FEL how long 'should' bucked remain up when parked?
   / FEL how long 'should' bucked remain up when parked? #61
A shock absorber has gas in it,, not fluid,,
if you put fluid in a shock absorber, it would be ridgid,,,
Go fill your bathtub full to the top with water,,, then get in the tub,,,
does the tub remain full, or does it overflow?
The cylinder must "overflow" to somewhere other than the cylinder, if the rod enters.
   / FEL how long 'should' bucked remain up when parked? #62
I'm going to, or have, learned something here! I'm going to go delete my post about testing the cylinder as seen in the video.
If I'm understanding this correctly the only way to test the cylinder then is to extend it, open the port above the piston, close the port below the cylinder, apply inward/down pressure on the piston/rod and check for drift??
   / FEL how long 'should' bucked remain up when parked? #63
Went to the barn today and the FEL has not moved at all.
   / FEL how long 'should' bucked remain up when parked? #64
   / FEL how long 'should' bucked remain up when parked? #65
   / FEL how long 'should' bucked remain up when parked? #66
Never tried it. I always drop the loader down turn the ignition off and wiggle the joy stick to take off the pressure just something I learned years ago from an old farmer saying it is easier on the hydraulics system.
   / FEL how long 'should' bucked remain up when parked? #67
I justs gots to know!
   / FEL how long 'should' bucked remain up when parked? #68
Still up about 2 feet. Wish my remote valves were that good. Get any snow today?
Nope. Iowa is gonna get hammered this weekend. We may get a dusting. Just cold here today.
   / FEL how long 'should' bucked remain up when parked? #69
So what did you learn?
   / FEL how long 'should' bucked remain up when parked? #70
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A56435)
2025 Mahindra 6075...
2001 KENWORTH T800 BOBTAIL KILL TRUCK (A58214)
2001 KENWORTH T800...
2005 CATERPILLAR 906 WHEEL LOADER (A52709)
2005 CATERPILLAR...
(3) BUG REFLECTORS IN BOX (A58374)
(3) BUG REFLECTORS...
Mini -Excavator Heavy Duty Rock Ripper (New/Unused) (A59225)
Mini -Excavator...
JOHN BLUE 1000 GALLON ALUMINUM NURSE TANK (A52708)
JOHN BLUE 1000...
