fel for B6100 Kubota????
   / fel for B6100 Kubota???? #1
jordanh
Bronze Member
Ashland, Missouri
B6100 4WD gear shift
I have a b6100 with a factory installed hydraulic front blade that has two levers...one to raise and lower and one to angle. There is no tilt control.
I got to wondering if I could weld up some heavy steel stock into arms, weld up a crude bucket, and plumb it into my existing controller to lift and dump?
Anyone attempted this? I believe the hydraulics run 3gpm.....which may be too low to effectively operate a loader. I just want it for veratility to do some light digging and hauling that the blade won't effectively manage.
   / fel for B6100 Kubota???? #2
I see no reason you couldn't use ideas from others loader builds to do what you want.
   / fel for B6100 Kubota???? #3
I think the B6100 used a front pto pump for a loader with the resevoir in the upright. I looked around for one for mine but decided to go with a rear scoop. All I need to do with it is move top soil around.
Good luck with you project. Let us know if you build one.
Rodger
2015 Manitou MLT840-115 PS 4WD Telehandler (A50657)
2015 Manitou...
2016 Caterpillar D6N LGP Crawler Dozer (A50860)
2016 Caterpillar...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
12 Ft Enclosed Trailer (A50324)
12 Ft Enclosed...
2011 Clarke JU4H-UFE0 4 in. Water Pump (A50860)
2011 Clarke...
2023 Komatsu WA320-8 Articulated Wheel Loader (A49461)
2023 Komatsu...
