Fecon - Eagle Claw teeth?
   / Fecon - Eagle Claw teeth? #1
kjravn
Swapped out Fecon double carbite teeth with a set of eagle claw teeth. There now is a noticable increase in vibration. There is a 1 lbs. differance in tool weight. Any advice?
Keith
   / Fecon - Eagle Claw teeth? #2
I would have thought , putting on a full set would have had no effect . But it may now need 1lb of steel stock welded to the counterweights on the rotor . Maybe a 1/2lb on each end , the correct way though would be to have the rotor re-balanced .
   / Fecon - Eagle Claw teeth? #3
Are you sure all the new teeth weight the same? You might need to ask someone who works at on on fecons how they are balanced. They may use a heavy tooth because it helps fine balancing. Balancing itself is a fine art on these units.
   / Fecon - Eagle Claw teeth? #4
We have changed out several sets. The only problem was the teeth were (shorter) exposing the back mounts.
Talked to fecon about balancing the drum they were helpful - did some shade tree dynamic balancing ended up welding on about a 1/2 lbs. weight to the left side which removed the excess vibration. All in all happy with the chipper teeth performance on the ASV PT 100 forestry
   / Fecon - Eagle Claw teeth? #6
Could you give more detail in the balancing you did???
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
72'' root grapple (A53421)
72'' root grapple...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
2025 JMR Tree Boom Skid Steer Attachment (A51691)
2025 JMR Tree Boom...
