Faulty ignition(?) on JD 1070
   / Faulty ignition(?) on JD 1070 #1
Rodent
Victor, NY
John Deere 1070
When switching the ignition switch to 'off', from engine running, the engine continues to run for anything from 10-30 seconds. Any clues as to the cause and its repair?
Any guidance appreciated. Rodent.
   / Faulty ignition(?) on JD 1070 #2
Check the fuel shutoff solenoid. It may be sticking, out of adjustment, have something fouling the linkage, etc.
Thank you!!
Spot on. A few drops of lubricating oil and voila!
2019 Caterpillar 815K Articulated Compactor (A49461)
2019 Caterpillar...
Kenco PH9000 Self-Leveling Pipe Hook - 9,000 LB Capacity, 8FT Max Pipe Length (A51039)
Kenco PH9000...
2011 Liebherr L586 (A51039)
2011 Liebherr L586...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2008 CAT 287C (A50854)
5th Wheel Dolly (A49461)
5th Wheel Dolly...
