Fastest, with the wide cut?
   / Fastest, with the wide cut? #1
riptides
Super Member
Northern Virginia
Kubota ZTR, RTV, MX6000
I am interested in real world ground speed with the biggest, widest, lawn quality, cut.
Which Kubota ZTR would be the best match?
I have flat stable ground, no obstacles, and am interested in mowing between 2 and 15 acres of grasses.
TIA
   / Fastest, with the wide cut? #2
ZD331/72 is the answer!
   / Fastest, with the wide cut? #3
:thumbsup:The one with 200 hp. and the 15' deck .
   / Fastest, with the wide cut? #4
There are 3 models that have a 10.6 MPH. with 72" decks ZG332, ZP330 and ZD331.
   / Fastest, with the wide cut? #6
   / Fastest, with the wide cut? #7
Seriously. If you dot have obstacles and level ground get the biggest deck finish mower you can find for the biggest tractor you can afford. I love my ZTR and can mow circles around tractors with similar sized decks but if you can cut three times the width...
Now I am back to looking at tractors, and just might purchase a new 50hp model with a 15ft mower deck.
It all comes down to how the landscaping works out around some new structures that are going up.
I may just opt out altogether and turn the "lawn" back to pasture.
   / Fastest, with the wide cut? #9
If you have any obstacles to mow around a 15' is going to be a nightmare. If its all wide open spaces, that 15' will put down a pile of acres! I have seen the great big gang finish mowers that do a heck of a nice job. My neighbor used to have me mow his "lawn" with an MX-10 with sharpened blades and it did a real nice job except for some barely noticeable ag tire prints. I surely wouldn't want to mow 15 acres every week and a half just to say I had a lawn though regardless of how it was mowed.
   / Fastest, with the wide cut? #10
Another option might be a WAM (Wide Area mower). Deere and Toro both make them. Used ones usually run $4-7k around here depending on condition.
Aaron Z
Ford F-450 Utility Truck (A51039)
Ford F-450 Utility...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2018 John Deere R4038 Self Propelled Sprayer (A50657)
2018 John Deere...
2021 Liebherr L556 (A51039)
2021 Liebherr L556...
2013 Ford Econoline E350 Passenger Van (A49461)
2013 Ford...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
