Farymann 43F Diesel Governor speed modification help needed.
   / Farymann 43F Diesel Governor speed modification help needed. #1
90cummins
Veteran Member
Florida Ma.
Ford 1720 SSS 4x4 Turbo Charged
I have 2 Military surplus MEP-952b 28v DC APU's 1 of which is being used to support my battery backup system.
These units use a German made Farymann 43f diesel engine rated at 15hp to drive a 280A DC generator.
I'm looking for anyone with knowledge that can help me modify the governor for steady state operation at 2000 rpm from the original 3000 rpm.
Another option would be to information to build/install an electronic variable speed control system.
The reason is to reduce fuel consumption when being used for battery support at lower power levels.
At less than full throttle operation the governor allows excessive droop when a load is applied.
Any information would be greatly appreciated;
Thanks 90cummins
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
2025 K1912 UNUSED Metal Livestock Shed (A50860)
2025 K1912 UNUSED...
Lot of 3 Dell Desktop Computer (A48083)
Lot of 3 Dell...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
Kawasaki 60ZV-2 Wheel Loader (A50860)
Kawasaki 60ZV-2...
Lot of 3 Dell...
