Farmtrac 360DTC rear tire width- 43.5 - 53.4 7 positions
   / Farmtrac 360DTC rear tire width- 43.5 - 53.4 7 positions #1
Slacker
Durham, NC
Farmtrac 360 TLB
I'm concerned with overall width/stance for the sake of stability on slopes.
I've ordered a new 360TLB with the largest industrial tires and will load them.
The farmtrac website states the rear width is adjustable from 43.5 - 53.4 with 7 positions. Can anyone confirm that I can get that width (or more?) with the upsized industrial tires?
This may be an option with the R1 rim/tire combo only. I'd like to make life a little easier on the dealer by letting him know what I want before he loads them with rimguard.
   / Farmtrac 360DTC rear tire width- 43.5 - 53.4 7 positions #2
Slacker I've wondering about this too. I have a 300DTC,same machine sans engine,with r4 tires and can't see how you can change the width.I'm sure the pros will chime in.
   / Farmtrac 360DTC rear tire width- 43.5 - 53.4 7 positions #3
Your wheels can be spaced like the wed site suggest. It's a matter of moving the dish to the inside of the bolt up blocks or outside. Or running the dish turned in or out and you can also swap sides with the wheels and then go back to the other options I just listed and get the correct width you want.
I bought a utility model and it was delivered with the wheels all the way in. I didn't ask the dealer to move them because he couldn't haul like I wanted it. The FT 80 will spread from 51.38-71.18(with 7 different widths). I run mine at 68 I think. I just swaped the wheels from each side with the dish still bolted to the wheel. That just turned the dish out from where it was turned in and the tire tread still runs the same direction. It now has the valve stems on the inside. They are a little harder to get to but I think they're a little more protected on the inside.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2015 FREIGHTLINER M2 (A50854)
2015 FREIGHTLINER...
2022 INTERNATIONAL MV607 26FT BOX TRUCK (A51222)
2022 INTERNATIONAL...
2018 Mitsubishi Mirage ES 4D Hatchback (A50860)
2018 Mitsubishi...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
UNUSED Garden Hose 164 ft. (A50860)
UNUSED Garden Hose...
