Mar 6, 2015 / Farmtrac 300DTC shuts off #1 S Slickwillie New member Joined Mar 6, 2015 Messages 3 Location Madison,Fl Tractor Farmtrac 300DTC I have a Farmtrac 300 DTC that starts when you turn the key, but shuts off when you release the key. Replaced ignition switch, did not solve problem
Monday at 2:37 PM / Farmtrac 300DTC shuts off #2 nakollar New member Joined Jul 14, 2025 Messages 1 Tractor 300 dtc Did you ever figure this out
Monday at 3:02 PM / Farmtrac 300DTC shuts off #3 O oldnslo Super Member Joined Jan 20, 2010 Messages 8,042 Location Northern, IL Tractor Branson 2400H, JD X540 I would suspect run circuit for fuel shutoff solenoid. Hook up a voltmeter or test lite to wire(s) going to the solenoid to see if you have any power on a wire with key in run position..
