pollolittle
- Joined
- Mar 30, 2011
- Messages
- 32
- Tractor
- John Deere 4200
Trying to help a neighbor fix his ride! He's convinced the motor is locked up and is on the fence to go buy a zero turn and turn the tractor out to pasture. I thought I would lend a hand, but unfortunately it appears this won't be simple and I am now in learn mode.
So, it is a FarmPro 2425. Was running fine and mowing, drove it up to the house, and while sitting there it died. Would not kick over or even attempt to kick over. Push the clutch in, and turn the keyswitch and it sounds like the starter engages for about a second and then stops. The motor doesn't budge or move or wink or dance, just stays stationary at the crank pulley.
If you jump the solenoid the starter will whirrrrrrr, but will not engage the flywheel.
He has already had the starter rebuilt, thought about taking it to autozone or somewhere to test it. Seems you could test it at the house also, just never done it. Pulled the starter off and made sure there was nothing jammed up inside the starter or against the flywheel. The bendix seems to be free and moves back and forth. The flywheel has some light wear on the outside edges of the teeth, but none are missing. Doesn't look like it has been trying to engage the flywheel. The bendix looks fine tooo.
We tried turning it over by hand, then by wrench, off of the crank pulley bolt. Unable to get it to budge, which is where neighbor thinks it is frozen. Should we be able to turn it and how hard should it be to turn it. I thought if we put it in high gear we might be able to push it and see if the motor would turn, we couldn't! Then we tried my small JD 4200 and we couldn't budge it either, so I'm thinking without a lot of effort it ain't moving anyway.
What is the shiny silver handle that goes from the operator station to the top of the valve cover?
