Sickle Bar Farmall H with side mount sickle bar mower
   / Farmall H with side mount sickle bar mower
Egon, good point about watching the fingers. There are definitely a lot of areas where not to put your fingers on a sickle bar mower. Beenthere I will have to take a look at the bar better the next time I go up to the farm. I usually go up there on the weekends. Actually I never even noticed the bow until it was mentioned but then I didn't know to look for it. Also a good point that when in the horizontal position the bow may flatten - I hope.
T-BOW
DonnieP,
Thank you for emailing me the manual. It will make for good reading and help me understand the parts of the mower.
T-BOW
   / Farmall H with side mount sickle bar mower #13
I have a 1944 Farmall H and I would love to put a mid mount sickle mower on it like the one you have here. Does anyone know the model number and where to get one? Did IH make one specifically for the H? Thanks in advance.
   / Farmall H with side mount sickle bar mower #14
Hi all, I have recently purchase a nice farmall super a with a side mount mower with the same serial number as was in the question. 464077-r1. I would like to purchase the operators and or servicce manual. Can anyone be of assistance? I live in central New York where it has rained for the last week so no corn planting. Time to get the a's oil changed.:thumbsup:
   / Farmall H with side mount sickle bar mower #15
Hello,
Check all of the sections(knives), to be sure that they are tight on the bar.
If the hay/grass, is just getting tangled, by falling on the cutter bar, try going to 3rd. gear to cause the hay to fall backwards, over the cutter bar.
Bob
   / Farmall H with side mount sickle bar mower #16
Hello,
Bob
   / Farmall H with side mount sickle bar mower #17
I don't know anything about the mower, but that is about the most beautiful tractor I've seen in years! I grew up on an H.
   / Farmall H with side mount sickle bar mower #18
Just a note to watch the fingers when working on the bar. And also when lifting and lowering it!:thumbsup:
+1 re. safe operation of sickle mowers. If it's clogging up frequently, there will be a temptation to clear it while it's still running to save time. Don't do it!
Toro Mower (A50324)
Toro Mower (A50324)
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
2013 Dodge Durango Crew AWD SUV (A55853)
2013 Dodge Durango...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2007 Ford Focus Hatchback (A54815)
2007 Ford Focus...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
