f450 tranny replacement questions
   / f450 tranny replacement questions #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
we have an f450 with a manual trans at work, in a service truck. it may have a pto .. not sure of year of truck.. but it has a 7.3psd in it.. thinking it is the last of the 7.3s in 04.
tranny has had it.. howls, growls, and jumps out bad.
here's the question.. if it has a pto.. what all will that fit on? only the manual? or an auto as well?
reason I ask is we also have an 04 f250 psd / 6.0 that has front end damage. we've found a good running f250 6.0 psd at a salvage yard that has rear end damage... it's priced right and if we take the front clip and radiator and cooler parts we need from it for our existing f250, it will be cheaper than buying the stuff straight out.... was wondering if that f250 auto trans will fit into the 450?
I need to find out for sure about the pto.
otherwise.. if no pto.. will the auto trans fit in?
if it fits in, what else has to be done? I know linkage for shifter and whatnot needs to be added.. any computer issues?
   / f450 tranny replacement questions #2
Yes trans is computer controled, you could swap in the 6.0 auto trans,wiring and PCM, sell the 7.3 for a hefty price. As for PTO if it has one and is used you would need a PTO trans.
ugh.. looking like a trans rebuild is cheaper..
   / f450 tranny replacement questions #4
Check out The Diesel Stop and look for a poster named Mark Kovalsky (he posts under his real name). Retired Ford transmission engineer. He might be able to give some guidance.
will do, thanks
1999 INTERNATIONAL PAYSTAR 5000 TANDEM AXLE DUMP TRUCK (A51222)
1999 INTERNATIONAL...
91013 (A48082)
91013 (A48082)
Kubota SVL95-2 High Flow Cab Skid Steer (A51039)
Kubota SVL95-2...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
