Mowing F3680 Cutting out
   / F3680 Cutting out #1
VicinOz
MF148
Hi all,
My 3680 goes great, but every so often, about once every five or ten hours, it just stops.
It will sometimes start right up and run for the rest of the day, and other times, it won't start again until the next day, or after a long rest.
When it stops, its like the stop solenoid - its that quick, so I replaced that. No better.
I also had an issue with the brake microswitch, so replaced that a while ago.
When I start it and it won't keep running, it does run until you let go of the starter, then it just dies immediately.
Any ideas would be appreciated!
Cheers, :confused:
Vic
   / F3680 Cutting out #2
If your solenoid is a 3 wire sol.? there are relays that make it run. Theres a "start" relay & a "hold" relay..
It sounds as if your "hold" relay is shot.. or the key switch is bad..
If you have a service manual, that should tell u where the relays are{I don't know}
THIS IS a very common problem..
   / F3680 Cutting out
Thanks for the speedy reply! I'll check it out in the manual and locate the solenoids. Thanks fully it's currently 'bust' so I may be able to isolate which one it is.
Cheers
   / F3680 Cutting out #4
Let us know what you find out.
   / F3680 Cutting out #5
IF you have to move it or NEED to run it, just remove the solenoid & tape/plug the hole..
Just remember, you wont be able to shut it down w/ the key switch..
Look at how the sol. works.. you'll have to reach in the hole & push the control rack..
OR.. the machine might have a manual shut down lever on it.. should be by the throttle lever..
Good luck.
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
Mk Diamond MK-101 Wet Tile Saw (A49461)
Mk Diamond MK-101...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2014 Ford F550 4x4 Bucket Truck with Versalift SST40 - 45FT Working Height (A51039)
2014 Ford F550 4x4...
2015 DODGE RAM...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
