Experience with rear PTO blower
   / Experience with rear PTO blower #1
TimberXX
Platinum Member
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
Does anyone have experience with this blower?
I want to use it on my 25 horsepower tractor
   / Experience with rear PTO blower #3
No experience with them, but they look interesting, I've never seen a squirrel cage style PTO blower.
I have an old furnace blower that I converted to run off a vintage B&S washing machine engine that I would take to steam and gas shows, it worked good at moving air, but I wasn't pushing it hard so not sure what it would be capable of.
Seems like it should move some air, not sure how it would compare to a regular paddle style fan or turbine.
One concern I would have is the blades of the fan might be slightly easier to damage so would have to be careful of ingesting debris.
I bet it's pretty quiet though.
Sent from my SM-S921U using TractorByNet mobile app
   / Experience with rear PTO blower #4
Two main tools for leaves here are DIY blower and recently a side discharge RFM. Years ago I built a blower from an old AHU blower. Worked pretty well. It took up space so I modified a set of blades for the 5' RFM.
I see people online coverting building fans to their tractors. Seems like a lot of work? how about the tractor spline to to fan (or pulley) attachment?
   / Experience with rear PTO blower #7
A lot of welding to make a rear three point table and sizing the V belt pulleys as the furnace fans are operating at much higher speeds.
A little wonder 3 wheel gas powered blower chained to a loader bucket or a rear mounted carry all would be simpler.
   / Experience with rear PTO blower #8
We purchased a Radtech PTO blower for use at the park I managed. I did a great job on gravel surfaces and a fair job on turf. If the grass was long or damp the performance was disappointing. Engaging the PTO was tricky because the thing was so high geared it tended to burn/glaze the belts - which were substantial in construction and cost.
We could direct the flow left or right. The discharge was close to the ground which helped. The blower in the OP appears to be up high and not focused.
In neighborhoods it would be easy to blow leaves onto another property - which wouldn't go over very well with neighbors.
   / Experience with rear PTO blower #9
Really wasn't rocket surgery. A simple angle frame to mount the salvaged squirrel cage fan, a little duct and a jackshaft on a pair of pillow blocks with some sheaves sized to replace the AC motor with a diesel:) The size of the sheaves were calculated to spin the fan the same speed the 3Ø electric motor did with the 540 PTO of the tractor.
As I said, it took up a lot of space so I scrapped everything but the angle frame and made a set of super hi-lift blades the side discharge 5' RFM. The frame became the basis for a carryall.
thats exactly what I have. Its a tired 5 hp unit, I really don't like the small engines just sitting around... but $3k is expensive
FRONT WHEEL SPACERS (A52708)
FRONT WHEEL...
2017 Ford Escape AWD SUV (A55758)
2017 Ford Escape...
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A58017)
2017 FREIGHTLINER...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A58018)
2023 PETERBILT 579...
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
