Exolain grappler to me
   / Exolain grappler to me #1
1930
Platinum Member
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
I dont undertand why I cannot buy a root rake/grappler and hook up the same hydraulics that my FEL would use.
Why do I need to buy a special kit and plumb in more hydraulic lines?
Why are the kits so expensive, what in the kits that add up to many many hundreds of dollars?
Help me to understand what I do not understand. Thanks
   / Exolain grappler to me #2
Because a grapple goes on the FEL in addition. You still need your basic fel controls, now you add a third function, clamping, hence the term, 3rd function.
I see. I did not know this but clear now.
   / Exolain grappler to me #4
Fyi for your info page, bush hog is a brand name, they are rotary mowers.
   / Exolain grappler to me #5
You can run the grapple lines to a rear SCV, (auxiliary hydraulic valve) if your tractor has one.
I have one that came with my first tractor
Mine will have one Im assuming cause it is being equipped with a backhoe.
Im guessing thats not all thats needed though?
   / Exolain grappler to me #8
Actually, no. The backhoe is connected to power beyond, which id different than a rear selective control valve.(scv). Power beyond delivers the full flow of the pump, without restriction, to the backhoe. The backhoe has its own valves that regulate the flow to the cylinders and back to the tractor.
You need a control valve, either a solenoid valve, which is what a third function uses, or a scv.
Once you have a valve then you need to run hydraulic lines. Hydraulic hose and fittings are expensive.
   / Exolain grappler to me #9
Kits are expensive because the components are expensive. A precision double acting solenoid valve and subplate, hoses, hose ends, joystick handle with button, all this stuff costs money.
   / Exolain grappler to me #10
Those are good questions. On your tractor - the first hydraulic function= raise/lower the FEL arms - the second hydraulic function= dip or raise whatever is attached to the end of the FEL( bucket, forks, grapple, etc) - the third hydraulic function= open/close the jaws of a grapple.
The third function valve is expensive because it is a fairly unique accessory. Same as adding additional SCV to the rear of the tractor.
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
2016 CATERPILLAR 259D SKID STEER (A50458)
2016 CATERPILLAR...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A51039)
Kubota 24in Quick...
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A51222)
2015 INTERNATIONAL...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
