exhaust smell
   / exhaust smell #11
Diesel exhaust smells bad? /forums/images/graemlins/confused.gif
   / exhaust smell #12
I think all the direct injected diesels smell a lot worse then the indirect ones do.
   / exhaust smell #13
On my 990 my exhaust reflects right off my FEL back towards me so its very noticeable and on occasion it gives me a headache, when I get my blade in and go pick it up I will order the vertical exhaust /forums/images/graemlins/grin.gif
   / exhaust smell #14
Are you sure it's a simple conversion to vertical exhaust on the 990? I too have the newer style 990 with under-hood exhaust (which I don't care for) and asked my dealer about replacing it with the vertical stack from the older style 990. He looked at the parts lists and the pieces have different numbers all the way back to the manifold. That would mean a new exhaust pipe, muffler, manifold, maybe mounting brackets, etc. He didn't think it was worth pursuing at all. If you find out different, let us know - I want a vertical exhaust!
If it is indeed more than a simple final pipe swap, I'll probably just build my own. The final pipe just bolts on to the muffler so it shouldn't be too hard to bend (or have bent) a different pipe that comes out the side and up. Fab up a flange to weld to the pipe and bolt it on. It would also require cutting a hole in the side panel, but that's no problem.
Actually, now that I think about it, maybe the old style JD pipe could just be modified with a different flange to bolt to the muffler ....
   / exhaust smell #15
Have heart. All diesels will start smelling better by about the end of 2006 when the sulfur gets bled out of the various distribution systems by the new low sulfur stuff coming into it from the refineries. Also, biodiesel will start becoming more available. It's completely safe to use up to around 20% biodiesel (labeled B20) in today's diesels, no matter what their age.
Ralph
   / exhaust smell #16
</font><font color="blue" class="small">( I think all the direct injected diesels smell a lot worse then the indirect ones do. )</font>
Pretty much the case. Primarily due to the compression ratios as direct injection runs less compression.
Adding 20% bio diesel blend to either will help with the odor tremendously.
1991 TRAILMASTER CRUDE TRAILER (A58214)
1991 TRAILMASTER...
2003 Mitsubishi Fuso FH (A57148)
2003 Mitsubishi...
2254 (A58376)
2254 (A58376)
SD Lanch SDLGC80 Electric Golf Cart (A57149)
SD Lanch SDLGC80...
2011 SOUTHWEST  GOOSENECK (A55745)
2011 SOUTHWEST...
2015 Ford Transit 150 Cargo Van (A56858)
2015 Ford Transit...
