BukitCase
Elite Member
- Joined
- Feb 17, 2012
- Messages
- 2,748
- Location
- Albany OR
- Tractor
- Case 580B, Long 460, Allis-Chalmers 160
Arly, just look for a 25 DINSE extension cable, you can get about any length you want - then you would just plug the extension into the welder, and the 5' ground cable into the extension. Everlast also lists a longer 1 piece,
but I personally hate pretty much ALL OEM ground clamps, I replaced all 5 of my welders' ground clamps with 400 amp bronze connectors... Steve
(You don't need a 400 amp connector for smaller welders, but you probably WILL need the ability to clamp onto larger than 1" stuff)
Ground Clamp DINSE 25 | Everlast Generators
Ground Clamp with 10 ft. cable and DINSE 25 style connector. Measures 3/8" across connector plug end. Used with smaller Everlast welders under 200 amps, and some plasma cutters.
www.googleadservices.com
