Easy Way to check your trans oil level!!!!!
   / Easy Way to check your trans oil level!!!!! #1
Leejohn
Elite Member
Doniphan, Mo.
Kubota L4240, B7800 & BX2660
Everyone knows how hard it is to see the oil level on the dip stick. I have a way that is easy, been holding up to post this, but here it goes. This is only for checking not running with it.
All it takes is a Bunn coffee maker cleaning tool and a rubber grommet. Bunn has 2 one is short and a long one, the bigger tractors well need the longer one. The tool should be the spring one. Set the grommet the same as your dip stick as a stop and so you don't drop it in the sump. Now check the oil and see how easy it is to read.
This well work on any sump as long it is long enough, and don't forget the front axle if 4WD.
As easy as ABC !!!!!!!!!
   / Easy Way to check your trans oil level!!!!! #2
All I have to do is LOOK at the sight glass to see if there is liquid showing. No dipping of sticks needed.
   / Easy Way to check your trans oil level!!!!! #3
Me too!:thumbsup: (might not be anyplace to check with a dip stick.)
For the front axle just look in.:thumbsup:
2014 Toyota Camry (A56859)
2014 Toyota Camry...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A58018)
2019 KENWORTH T680...
2006 Ford F-250 Service Truck (A56858)
2006 Ford F-250...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
8' X 42" X 10' PALLET RACKING (A58374)
8' X 42" X 10'...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
