Easy Way to check your trans oil level!!!!!
   / Easy Way to check your trans oil level!!!!! #1
Leejohn
Elite Member
Doniphan, Mo.
Kubota L4240, B7800 & BX2660
Everyone knows how hard it is to see the oil level on the dip stick. I have a way that is easy, been holding up to post this, but here it goes. This is only for checking not running with it.
All it takes is a Bunn coffee maker cleaning tool and a rubber grommet. Bunn has 2 one is short and a long one, the bigger tractors well need the longer one. The tool should be the spring one. Set the grommet the same as your dip stick as a stop and so you don't drop it in the sump. Now check the oil and see how easy it is to read.
This well work on any sump as long it is long enough, and don't forget the front axle if 4WD.
As easy as ABC !!!!!!!!!
   / Easy Way to check your trans oil level!!!!! #2
All I have to do is LOOK at the sight glass to see if there is liquid showing. No dipping of sticks needed.
   / Easy Way to check your trans oil level!!!!! #3
Me too!:thumbsup: (might not be anyplace to check with a dip stick.)
For the front axle just look in.:thumbsup:
New/Unused 72inch Quick Attach Vibratory Roller (A57454)
New/Unused 72inch...
2014 FOREST RIVER WILDWOOD RV TRAILER (A58214)
2014 FOREST RIVER...
Weber CR5 Reversible Plate Compactor (A56857)
Weber CR5...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2017 Ford F-150 XLT 4x4 Crew Cab Pickup Truck (A55973)
2017 Ford F-150...
UNUSED FUTURE 32"...
