Dumb question: Why do you need Ballast?
   / Dumb question: Why do you need Ballast? #1
newdeal
I have been doing quite a bit of reading and I heard people talk about ballast when using the front end loader. I know Deere makes a ballast box, not sure what kubota has but I am thinking like many have said a box scraper on the back would add some nice ballast. In my mind its because as you put weight on the loader it will tend to lighten the rear tires and since the front tires will dig in it will reduce traction. Or is it due to a roll over risk if you try to lift something too heavy up front? Just wondering because I am planning to get a 2360BX and just didn't know how much loader work you can do without ballast and what the ballast is trying to prevent
Also how big of a box scraper can a bx2360 pull (to work the driveway and fill in pot holes as well as work some soil which in my area is clay)
   / Dumb question: Why do you need Ballast? #2
When you have a full FEL, the tractor becomes very front heavy. It only takes a small bump or off camber situation to make you feel like you are going to tip over (sideways). Keep your FEL as low as possible when hauling, and be ready at all times to drop it to the ground if you feel tippy. Ballast keeps your rear end firmly planted on the ground.
I keep my back hoe on my unit, and it is very good ballast. A box blade can do the same, especially if you add some weight to it. I don't like ballast boxes because that is all they do, add weight. You can get that weight with other attachments that are actually tools serving a purpose. You can also add wheel weights to your rear wheels, and never have to think about it again. Filling you tires with foam or liquid is excellent also.
   / Dumb question: Why do you need Ballast? #3
traction and stabiliity weight on rear weels is best.
   / Dumb question: Why do you need Ballast? #4
..... In my mind its because as you put weight on the loader it will tend to lighten the rear tires and since the front tires will dig in it will reduce traction. Or is it due to a roll over risk if you try to lift something too heavy up front?..........
Your reasoning is exactly on point. Ballast stabilizes the tractor under varying front load, both for rear traction and tip resistance. People with flat land think about this less, but those with hilly uneven land think about stability all the time. Filling the rear tires with heavy liquid and spacing them out wider are both beneficial. A heavy rotary cutter back there does a good job, even if it can sometimes get in the way. The box blade idea is good too.
   / Dumb question: Why do you need Ballast? #5
Agree with previous posts, I use wheel weights on my BX2660 and liquid on everything else in addition to a BB or something heavier. I have used FEL sans ballast, but do not recommend it.
As to the second part, my preference is for a four foot on a BX. It will handle a five foot, just not quit as well and is easy to snag.
   / Dumb question: Why do you need Ballast? #6
I have my rear tires filled to provide traction and it is also weight down low that helps with stability. When I'm using the FEL, I add weight to the TPH, that adds even more traction and provides a counterweight for the load in the FEL. Two different reasons to use weight, I could add wheel weights to hold the rear down when the bucket has a heavy load, but that does nothing to counteract the extra weight on the front axle.
   / Dumb question: Why do you need Ballast? #7
All of the above are good answers. It helps to have the CG (center of gravity) as low as possible and as evenly centered between the 4 wheels as possible.
The comments about a loaded FEL are especially pertinent. Even with rear ballast, a loaded FEL, even when low and traveling slowly can cause a tractor to start tipping and lifting off the opposite rear wheel when turning on even a very mild grade. Just like test pilots trying something never done before in a new plane, every possible situation you might encounter in an attachment configuration you haven't done before, should be tried very carefully. Changes in weight in the FEL, grade of terrain, speed, sharpness of turn, all have significant impact on the sum of the physics involved. More than a few good men have been seriously injured or killed doing something they had not tried before, all the time thinking it would be completely safe. Take the time and caution to get the feel of anything new when operating powerful and/or heavy machinery. One little mistake could be your last.
   / Dumb question: Why do you need Ballast? #8
Beyond stability, rear (3ph) ballast when using the FEL avoids overloading the front axle.
   / Dumb question: Why do you need Ballast? #9
Don't be too quick to reject the ballast box either because you can put a lot of weight in there with cement blocks and gravel/sand or rocks and keep things quite close to your back end if you have tight spots to work in with the loader. Try maneuvering in the woods with a box blade hanging off there. Also some of us put PVC tubes down in there to hold rakes, shovels, etc. I also have a milk crate sitting on there (just below the lip and on top of the gravel) to hold my chains, chainsaw helmet or rock hammer and chisel or whatever else I might be using on that job. Got all these ideas from this forum.
   / Dumb question: Why do you need Ballast? #10
I don't know how you get to that conclusion.
It allows (ENCOURAGES ?) a bigger load on the front axle by providing stability.
It is a balancing load behind the front axle to balance the FEL's load in front of the front axle.
Net result is more load on the front axle.
NEW Fork Extensions (A59000)
NEW Fork...
2014 Ford F-250 Crew Cab 4X4 Pickup Truck (A55973)
2014 Ford F-250...
GRAIN AUGER (A52708)
KMC 6R30" RIPPER / HIPPER (A52708)
KMC 6R30" RIPPER /...
1998 Volvo VN T/A Dump Truck (A56858)
1998 Volvo VN T/A...
SET OF ALUMINUM RAMPS (A58374)
SET OF ALUMINUM...
