Dt466 smokes terrible and I can’t figure out why.
   / Dt466 smokes terrible and I can’t figure out why. #11
How old is the truck? White smoke can be caused by low compression, retarded timing, or low cetane fuel.
I would start by purging the fuel and installing fresh filters, especially if the truck has been sitting for a while, and running the engine on known good fuel.
The DT 466 has had at least four fuel systems over the years, the Ambac Model 100 rotary distributor pump, the Bosch MW and P Pump, the electronic HEUI, and the G2. Retarded timing or air in the fuel system will cause white smoke. Make sure there are no O ring leaks and that the return checks are functional.
A worn out power cylinder will have inadequate compression to support combustion. Hard starting is the first symptom, but white smoke follows.
Pull the valve cover and check valve lash. Worn valve train components can cause issues too.
It’s 1970s or 80s. It starts good. I guess I should finish the compression test and change the fuel first thing.
   / Dt466 smokes terrible and I can’t figure out why. #13
How old is the fuel? It sounds like this thing may have been sitting a while before you bought it.
If it was last filled with biodiesel, the fuel could have deteriorated and cause white smoke.
It’s sat a few years. I don’t know if the previous owner changed anything.
   / Dt466 smokes terrible and I can’t figure out why. #15
Dump some sea foam in the fuel and oil. Take your time start with the simple easy things .
New/Unused SD Lanch 20x30 All Steel Carport (A57454)
New/Unused SD...
2019 Dodge Charger (A56859)
2019 Dodge Charger...
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
Heavy Duty 44in Excavator Rake (Fits CAT 305) (New/Unused) (A59225)
Heavy Duty 44in...
VINTAGE SCOTT - ATWATER 5HP OUTBOARD MOTOR (A58374)
VINTAGE SCOTT -...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A55973)
2017 Freightliner...
