Dry my pastures out
   / Dry my pastures out #11
"I have read about an old technique like tiling, but without the "tile" ...an implement was pulled through the ground to create underground voids or channels ...the implement was a relatively thin blade with a torpedo shape at the bottom end (think of a subsoiler but with a streamlined business end)...once it entered the ground and was pulled along, a little tunnel was formed subsurface and the slit to the surface healed itself ...took a lot of power ...some times pulled by a drag line from a stationary engine at edge of field if the area would not support a tractor ...the "torpedo" compressed earth around its "bow wave" and left the tunnel with compressed earth sides in its "wake" ...much like horizontal compression boring"
That's called a mole plow. Pretty cool but a rare bird.
I bought a subsoiler and ran a series of parallel rows running down the gentle slope to perhaps allow drainage. Of course I also worked the surface to slope the ground towards a ditch. This winter is the first test of the grade and subsoil technique. A subsoiler sure tears up the ground and makes a mess.
   / Dry my pastures out #12
riptides said:
What can I do to dry my pastures out?
What did the old farmers use to dry them out? Did they not use a tile? How did they get it in ground?
-Mike Z.
Be discreet, don't advertise what you are doing to avoid running into trouble with the DNR in your state. Being honest with the State or County or City on your plans can sometimes lead to so much regulatory grief you will regret being nice and honest.
Bob
   / Dry my pastures out #13
If the contour of the land would support it, how about cutting in a swale to direct water to the stream. Here a swale would be a wide shallow ditch with very gently sloping sides so it would not interfere with mowing.
MarkV
   / Dry my pastures out #14
I'm with Mark. I will always cut a wide drainage ditch first. It's foolproof and one hundred percent effective.
The downside is you have to spend lots and lots of time on a tractor. hahaha
Eddie
   / Dry my pastures out #15
As stated by Happy, make sure you know what you are doing legally before you do it. Being discreet and sneaky like my neighbors did when they drained their wetlands is going to cost them a small fortune. Not to mention our lawsuit against them for dumping their water onto our land, destruction of our culvert and washed out land areas. Be forewarned, draining water can and will cost you if you are in a wetlands area, drain the water illegally, or onto anothers property. That also includes increasing the flow of water into a brook or stream which can lead to flooding dowstream from your place. Silt and soil runoff from your project will be another main issue if any Government Dept's get involved. The DEP looked at my neighbors pipes recently and said that there was no signs of silt runoff after the neighbors and I complained of brown water flowing into the pond down the street which leads to a drinking water reservoir. I took pictures of the water leaving the pipes from the neigbors property during the last rain storm a week ago. It was nice and brown. Those pictures were forwarded to all concerned parties, DEP, DCR, Con Com, Water works, Board of Health and a few others.
WHITE CI-7 DRAW WORKS POWERED BY TWIN (60 SERIES) DETROIT 14.0L ENGINES (A50854)
WHITE CI-7 DRAW...
2011 FREIGHTLINER M2 TANDEM AXLE FLATBED TRUCK (A51222)
2011 FREIGHTLINER...
AC CHARGING MACHINE (A50854)
AC CHARGING...
SCAN TO RECEIVE TEXT UPDATES (A51242)
SCAN TO RECEIVE...
1267 (A50490)
1267 (A50490)
2015 VOLVO VNL TANDEM AXLE SLEEPER (A51219)
2015 VOLVO VNL...
