Rear Blade driveway/land plane, homemade dimensions/drawing?
   / driveway/land plane, homemade dimensions/drawing? #1
mstone34
Brandon, MS
Kubota M4030
I am new here and wish to make 7' grader/land plane. I need diagram and dimensions, etc. Any help here?
Thanks for your time, Mal
   / driveway/land plane, homemade dimensions/drawing? #3
Do a little searching on TBN as there are some really great products that people have made. Impressive ones.
   / driveway/land plane, homemade dimensions/drawing? #4
Don't know how heavy your tractor is, info says 4000 -7300lbs. If you are on the lighter side, I would suggest that you only build a 6 footer. Either way, try to get it up in the 1000lb range and be sure that the sides are no less than 60" in length and 72" would get you a better finish grade. Is your main use going to be for roads or landscaping? Some guys prefer for the blades to be straight for landscaping purposes, I don't think that it really makes much difference myself.
I know that there seems to be roughly 3 different heights used for these graders. 12", 18" & 24" sides.
Good luck with your design & build, don't forget to post pictures, we all like pictures. ;)
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
Truck Metal Cargo Storage Box (A55788)
Truck Metal Cargo...
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
Massey Ferguson 9250 (A55315)
Massey Ferguson...
2003 Pierce Spartan Pumper Fire Truck (A54814)
2003 Pierce...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A55301)
DeeZee Crossover...
