Driveway Drainage Ditch Question??
   / Driveway Drainage Ditch Question?? #1
TractorTeen
Bronze Member
Virginia
Kubota B2910
I have put in these drainage ditches for the water to run off from my driveway. I am going to fill with some 2" - 3" rock. I was wondering if I should lay some corogated drain tile or pipe to carry the water. Would this help any?
   / Driveway Drainage Ditch Question?? #2
If you lay pipe, plan on it filling up.. bigger pipe just takes longer. Look at your local municipality drainage easements... mostly open swales.. pipes under driveways, ditch blocks where necescary to limit flow.. riprap / 'energy disipators' at flumes to prevent erosion where the water finally discharges..
Soundguy
   / Driveway Drainage Ditch Question?? #3
I concur. A ditch will generally handle more water than a pipe. The issues with a ditch are generally to keep it from eroding. Your rock lining will help with that. Rock check dams, as mentioned by Soundguy, can be a good (and cheap) idea.
Well, making a ditch too flat can be a problem too, but it sounds like you have grade to burn. /forums/images/graemlins/wink.gif
2011 JOHN DEERE 310SJ BACKHOE (A51242)
2011 JOHN DEERE...
UNUSED FUTURE MINI EXCAVATOR RIPPER (A51244)
UNUSED FUTURE MINI...
20' One Trip Shipping Container (A50514)
20' One Trip...
SCAN FOR HAULING AND FINANCING INFORMATION (A51243)
SCAN FOR HAULING...
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
Ficklin Mod. 4500 Gravity Wagon (A50514)
Ficklin Mod. 4500...
