Does anyone use a machete to clear walking trails?
   / Does anyone use a machete to clear walking trails? #11
Well I'll second the ditch blade (bush axe) as one mean tool. I find it rather heavy to carry if you only have light stuff to cut. If you are after sapling it is hard to beat. Alway thought I would make a bad weapon to run up against.
The Woodsman's Pal is also sold by Chainsaws, Outdoor Power Equipment and Tree Care Supplies from Bailey's . Pricey but a good looking tool.
MarkV
   / Does anyone use a machete to clear walking trails? #12
Being a land surveyor I used machetes for a long time but then a coworker introduced me to the Swedish Clearing Axe and I never used a machete again. This thing makes cutting everything from briar brush to vines and trees up to 6" diameter easy. It stays sharp very long and has a great heavy feel to the swing. Replaceable blades mean you only buy it once and just replace or sharpen the blades as needed.
   / Does anyone use a machete to clear walking trails? #13
+1 for the Gerber "beaked" machete!
I tied a double thickness of leather cord through the handle hole, long enough to loop around my wrist - makes for a nice secure carry and swing.
- Jay
   / Does anyone use a machete to clear walking trails? #14
Forgot to mention how surprised I was at the durability of the little Gerber. I've used mine hard for several years and only had to do some minor touchup on the very sharp edge. And that "plastic" looking handle is apparently fiber-reinforced 'cause it can take a real beating.
- Jay
   / Does anyone use a machete to clear walking trails? #15
I havent used a machete in years, My first thought is if a machete will cut it my brush hog will have a field day with it. If the tractor wont fit between the trees my Stil weedeater will. A machete in todays time is to much work for me!
   / Does anyone use a machete to clear walking trails? #16
I find that I really use the machete to get rid of those "eye poker" branches on WALKING trails. Admittedly nothing beats a trimmer to take stuff off at the ground and those brush axes are handy -- guess it is just what you get used to.
Tim -- why let the trees stop you -- get a dozer:p
I understand, but where I'm talking about there is positively no way anything larger than a lawn tractor will make it through the trees and my 8' brush cutter is on a 100 hp tractor. Besides, it's not exactly comfortable going for walks carrying a string trimmer; especially when my trimmer with a blade on it is a Stihl FS350. Also, when I go riding an ATV there the Stihl won't fit in the saddle bag very easy either.
   / Does anyone use a machete to clear walking trails? #18
Hmmm Hmmm, I also am a swingblade man. Hmmm Hmmm. Just like in the movie...
Seriously though, Like HCJ said...The one with the bolts I also have found are the best...with more weight. I have a couple cheaper, lighter ones and don't use them. Once you get one you will never be without it. Mine lives in the back of my truck. Hmmm Hmmm.
   / Does anyone use a machete to clear walking trails? #19
I have more machete time than I care to think about. It is most certainly my most used outdoor tool, and it is a rare day That I am out on my property without it. If I had to be stranded anywhere, it would be the one tool I would most like to have. I could make any other tool, weapon or shelter I needed using it. The key IMO is weight VS length. The large head heavy ones though good used on thicker stuff like an axe, will wear you out swinging at small stuff. Blade thickness is very important. Avoid the thin surplus store and wallmart ones. They have too much blade flex when striking heavier branches, which can lead to unexpected and uncontrolled glancing blows. IMO, a blade with a 1/8"(.125") thick back is about right. Apparently someone else thought so also, as it was written into a millspec.
I have owned/used several, and the best one I have is the 18" millspec model made by the Ontario Knife Company. The others I have will work, but they are just not as efficient as the Ontario model. You can see one down near the bottom of this page. Welcome to Ontario Knife Company! They have manufactured these for decades. I have owned mine for well over 20 years. They make an updated version with a handguard and a colored handle(same blade as the milspec but with a molded handle). If I had to get another one, I would probably get one like the model 8516 seen on this page. Welcome to Ontario Knife Company! But in 20 years of hard use, I have been unable to wear my current one out:) I have on occasion missplaced it in the woods, so a colored handle would be handy. IMO, 18" of blade is the ideal length. It is also very easy to carry and store on tractor or truck.
Whatever you use, put a wrist strap on it. If you are working in stickers or thorns, you will want to wear gloves, and hot sweaty hands, or gloved hands can sometimes have grip issues. An 18" blade flying thru the air uncontrolled can be a real bad thing... Cut branches/logs at an angle steeper than you would use for a axe(30-45 degrees). This allows the blade to sever the wood strands easier, like a Katana sword slicing thru a rolled straw mat. As you use it you will find there is a sweet spot where the cutting seems to be effortless. This spot for me seems to be back from the tip about 6". Once you get the swing of it, you will wonder how you ever worked in the bush without one. On tree trunks up to about 8", I can hack my way thru faster and with less effort using the machete than I can with an axe.
Good luck and be safe. The part about taking a leg off? That mans father was right in that regard.
   / Does anyone use a machete to clear walking trails? #20
No... but I do remember FIL with a Bolo knife in the Philippines when I asked for his daughter. I also remember VDOT yellow trucks with black and white jumpers in the back cleaning ditches and brush from roadways... one guy sat on the bank with a handgun and another walked around with a shotgun! Dad always said not to get too close. Worked well for many years and most of the guys went on to be successful in life! Hard Work at the time!
mark
2025 JMR 36in Mini Skid Steer Bucket Attachment (A50322)
2025 JMR 36in Mini...
Joy Air Tugger Winch (A50860)
Joy Air Tugger...
2018 PETERBILT 579 DAY CAB (A51222)
2018 PETERBILT 579...
2015 FREIGHTLINER M2 (A50854)
2015 FREIGHTLINER...
Genie GTH-644 (A50490)
2010 Cadillac CTS Performance Sedan (A48082)
2010 Cadillac CTS...
