Do you have a srew loose?
   / Do you have a srew loose? #1
RJohnson
Texas
my 18 horse Sears doesn't even count as a tractor
One of the problems we encounter at my company is that after tightening fasteners to specified torque, we find the nuts becoming loose or reduced torque values. I personnally have never been a proponent of torque values, there are too many variables that affect torque and not all of them related to the clamping force of the bolt used.
Well to make a long story short we have stumbled across a supplier of a securement device that we hope will eliminate our nuts coming loose/w3tcompact/icons/shocked.gif/w3tcompact/icons/blush.gif after they have been "torqued".
Tractors are notorious for losing fasteners, this device called a Nord-Lock has shown to be a better "mouse-trap" than either torque prevailing lock nuts or nylon insert lock nuts. I am including a link so you can check it out yourself http://www.nord-lock.com
The device is expensive but you can eliminate a washer by using the Nord-Lock and it couldn't be any more expensive than a replacement nut, bolt and washer./w3tcompact/icons/smile.gif
Just tightening down a nut by hand and then trying to loosen it takes more force because of the cam action of the Nord-Lock. Anyhow a little info never hurt anyone. Enjoy.
Randy
   / Do you have a srew loose? #2
RJohnson,
"Do you have screw loose" heck I thought you were responding to one of my post. /w3tcompact/icons/smile.gif
I checked out the website and seems like a good idea but have a question.
If I wasn't useing a torgue wrench on a 3/4" plus nut how would this washers stand up compare to a washer..lock washer?
For 3/4" plus nuts grade 6 or better I tighten {spinach time} them as much as I can.
Thomas..NH /w3tcompact/icons/wink.gif
   / Do you have a srew loose? #3
The loose screw post sure caught my attention!
Thanks for the link, used some quite a while ago and the really hang on;). Now if TSC would start stocking them...
Thomas,
Most fastener lock nuts depend upon friction, torque values are really an indication of friction developed between the thread elements. The Nord-Lock uses tension, as the cam planes move in relationship to each other they try to separate and increase the tension load of the nut on the bolt. Its a pretty nifty idea. Split ring lock washers are trying to do the same thing, put more of a tension load on the nut. I do not think the split ring will achieve as good as a tension value as the Nord-Lock. The split ring tension is dependent upon the metallurgy of the steel whereas the Nord-Lock is a mechanical design which should give more consistent results.
Randy
   / Do you have a srew loose? #5
RJohnson,
Thanks for the info,and by the sounds the may just work great on hay bailers..hay rakes etc.. w/moving parts.
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
2008 INTERNATIONAL MA025 FLATBED (A55745)
2008 INTERNATIONAL...
Landoll Lowboy Trailer (A55315)
Landoll Lowboy...
