DK45 service manual - Front axle problem
   / DK45 service manual - Front axle problem #1
CajunRider
Platinum Member
Cajun Land
Kioti DK45
I am having a leak on the front axle of my DK45. I will order a service manual. In the mean time, if any one has a DK45 service manual, I'd appreciate it if I can get a few scanned page of the front axle.
Thanks in advance.
   / DK45 service manual - Front axle problem #2
Where exactly is the leak coming from? A parts manual would also be very helpful to purchase along with the service.
I am not sure yet. I'll have a look at it today. Since it is on my property, I am not there every day. While waiting until I have time to either fix it or take it to the dealer, if I run in 2WD only, can I still use the tractor with low risk of making things much worse?
   / DK45 service manual - Front axle problem #4
How bad is the leak? Is it leaking all the fluid out? If so then I would not use it, but if it is just seeping and not affecting the level then you would be fine to use it.
Most of the fluid has leaked out. The fluid oozes out right the the very end of the axle near the rim of the wheel. I really need the diagram for the part in that area. I am planning to stop by the dealer this coming Wednesday afternoon and order a service manual. I wish I have a scanned copy of the diagram so I can get going a little earlier.
   / DK45 service manual - Front axle problem #6
I know a guy Jon DePratt that would ship a manual to you from Columbus Kansas /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif
2803 (A50460)
2803 (A50460)
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
2011 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2011 TROXELL...
1992 GROVE AP-308 CRANE (A51222)
1992 GROVE AP-308...
1041 (A50459)
1041 (A50459)
