dk45 or dk50 for blowing snow
   / dk45 or dk50 for blowing snow #1
musselmark
grand tracadie PE
'05 NH TN75DA
I plan on buying either a DK-45 se hst or a DK-50 se hst mostly for blowing snow. Is there any sense paying an extra $1500.00 to go from 36pto hp of the DK-45 to 37.5 pto hp of the DK-50? Also should I get a 6' or 6.5' blower.
   / dk45 or dk50 for blowing snow #2
Snowblowers really like HP. Indeed, you are in the land of diminishing returns between the two, so if you have more time than money, stick with the 45...but spending $1500 now might give you that extra throw you just might need later.
   / dk45 or dk50 for blowing snow #3
My experience is that snow blowers like RPMs more than hp. I have a 5' Monitor on my ck 20 and it throws snow way over there. I have never had it bog down, even in wet snow. Now if it is too wet, it will clog the chute, but it is still turning.
I suppose someone might want a definition of "way over there", I would say it spreads it from 20-40' away depending on how you have the chute deflector set. There are no snow banks to worry about. Oh, and don't point it toward the house.
   / dk45 or dk50 for blowing snow #4
I have a DK40se and an older Pronovost 74 inch blower. I have to slow my speed in reverse to let the blower catch up sometimes but it will move even the heaviest snow. I would spend any extra money on a good quality blower. Spending more to get a better blower will be more noticable than the difference between the DK45 or DK50. Visibility is excellent in the Kioti DK cab. Let it snow, let it snow.
   / dk45 or dk50 for blowing snow #5
I think some of the $1500 difference could be spent on getting a better blower, $500 spent that way could make far more difference than 3% more hp. I think with the HST too, a wider blower is probably better unless you have snow conditions deep enough that warrant a double auger blower.
It really doesn't make any sense that they would bother making a seperate tractor model with 1.5 more PTO hp, does anyone happen to know the engine torque specs, maybe there is a bigger difference there. Is PTO power ever measured by torque instead of horsepower?
I found it on their website, the 2.2 engine 140 Nm and the 2.4 engine has 155Nm which converts into 11 more foot pounds of torque
   / dk45 or dk50 for blowing snow #8
I have a Blizzard, B74 (74 inch) blower on my LK3054, that has 23 HP at the PTO. I sometimes have to run in low range, but have never had an issue moving snow, even the road plow windrow; actually seems to work better in a moderate snow fall (12 inches or so) than in a light snow, 6 or less :confused3:
   / dk45 or dk50 for blowing snow #9
An important question nobody has asked is how your using it. Do you have 1000`feet of driveway that cuts across an open field or a smaller enclosed area? Drifts and snow conditions will play a big difference. Either will power the same blower the only difference you MAY notice is how fast you can move with it. If shaving a minute or two off the job each time is important to you, go with the DK50. I started asking about the DK50 and my dealer had one in stock, but for a bunch of reasons, he had more room to negotiate a better price on the DK45 that he also had in stock so it would have been more like a $2500 difference between the two. That's more of what I would base my decision on.
2016 INTERNATIONAL 4300 SBA FLAT TOP ROAD TRACTOR (A58375)
2016 INTERNATIONAL...
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
Yanmar YT359 (A53317)
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
2015 Mitsubishi Outlander Sport Multipurpose Vehicle (MPV), VIN # 4A4AP3AU0FE026699 (A56859)
2015 Mitsubishi...
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
