Disc Harrow Disc harrow options for Johm Deere 1050
   / Disc harrow options for Johm Deere 1050 #1
Deere1050
Buchanan, Michigan
John Deere 1050
As mentioned in the title I'm looking at options for a disc harrow for my John Deere 1050. I currently farm about 2 acres of sweet corn and am looking to upgrade from my old dual gang pull behind disc to something that is three point mounted. The ground is mostly clay and is terrible to work in the wet spring months. My issue is I don't know how big I can go as far as disc the tractor is 4wd and has R1 tires but I have bogged it down with a 2 bottom plow. Any input would be great and thanks for reading this.
   / Disc harrow options for Johm Deere 1050 #2
Do you have an FEL?
Are your tires loaded?
How wide are your rear wheels set?
Are you going to plow every Fall before smoothing with the Disc Harrow? (7-1/2" pan spacing)
Are you "no till" and want to till in crop stubble? (9" pan spacing)
What about food plots? What about firebreaks? (9" pan spacing)
   / Disc harrow options for Johm Deere 1050 #3
I own a John deere 870 with mfwd with non loaded ag tires and no front end loader,but i do have four weights on the front.i run a six foot wide landpride disc harrow (dh1572) with no problems.
   / Disc harrow options for Johm Deere 1050 #4
And the diameter of those discs are??
   / Disc harrow options for Johm Deere 1050 #5
18 inch notched.
I do have a FEL and no I don't have loaded tires. Rear wheel spacing is at 71 inches and I plan on moulboard plowing every fall. I dont have any food plots right now and don't plan on working any, and as far as firebreaks go I'll just end up using my old disc.
   / Disc harrow options for Johm Deere 1050 #7
You need a Disc Harrow with Box Frame construction. An angle iron Disc will not give you the weight you need, they are minimally adjustable and in your stoney soil will loosen up quickly.
You will be able to pull a Box Frame Disc Harrow with 18" diameter pans with no problem. Depending on how thick the pans are this will give your from 37 pounds to 40 points bearing on each pan, which is the minimum necessary to be effective. You will be able to set the gang angles as aggressively as you like and still pull the implement at a good soil mixing speed.
Almost all Disc Harrows with 18" pans come with notched (scalloped) pans front and rear to improve cutting.
You can buy a Disc Harrow with either 7-1/2" or 9" spacing between pans. As you are going to moldboard plow I would buy with 7-1/2 inch spacing as it will leave your soil quite level and smooth.
Almost every Disc Harrow manufacturer makes 16/18" (9" spacing) and 20/18" (7-1/2" spacing) in 6' to 8' width. Keep in mind that some spec DHs with gangs flat, to advertise max width, but you will be using with gangs adjusted >< so your working width will be less and will be variable. You will be able to pull an 20/18" eight feet in width if you desire. Land Pride 18" DHs all have 7-1/2" spacing, 72" + 90" (flat?)
I have a Howse 16/18" (587 pounds) for which I paid $1,000 (new) in February 2013. TSC's "Countyline" is currently produced by Tarter in Kentucky. Land Pride is a cut above Howse and Countyline. There are many others. Most have CLAMP PLATE adjustment of the gang angles, which works fine but is slow to adjust.
Everything Attachments in North Carolina has DH with good weight and SCREW ADJUSTMENT of gang angles, which costs more but is convenient. Freight might be considerable to Michigan.
You may want optional (clay) disc scrapers on your DH, or you can rig chain loops between pans to cut off clay accumulation.It is best not to churn wet clay, but sometimes you have to get into the field under less than ideal conditions.
Buy as much weight as you can afford.
From my experience with both 18" and 20" diameter pans, you will not have enough power to pull a disc with 20" diameter pans, which are 50% heavier than DHs with 18" pans.
LINK: http://www.tractorbynet.com/forums/attachments/308251-disc-harrow-selection-18-45-a.html?highlight=
LINK: DH15 Series Disc Harrows | Land Pride
LINK: Everything Attachments XTreme Duty Deluxe Box Frame Disc Harrow
Jeff- Thank you for the quick and very informative reply I appreciate it greatly. As far as the discs go I have been looking at the Land Pride 1590 and plan on getting a quote for one with 18" discs and scrapers. My only other question would be is it worth buying a used model with the same specs as I'm after as long as it is in the same condition?
   / Disc harrow options for Johm Deere 1050 #9
YES. Disc Harrows are tough implements.
LOT: Cutters, Shears, Giant Chalk Line, 100' Tape Measure (A59076)
LOT: Cutters...
2020 DRAGON ESP...
SET OF PRECAST STEPS (A58374)
SET OF PRECAST...
2015 Peterbilt 348 Dump Truck (A55973)
2015 Peterbilt 348...
Mini-Excavator Quick Coupler (New/Unused) (A59225)
Mini-Excavator...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
